fuel injector wires on my rb26 is dry rotting and needed to be replaced, can i use the rb25 injectors and just match the wires along with connectors and create a fuel injector sub harness w/o the drop resistor ?
RB25 Pin out http://1jzmerc.com/files/pdf/pinout-nissan-ecr33-rb25det.pdf
RB26 Pin out http://1jzmerc.com/files/pdf/pinout-nissan-rb26dett.pdf
RB25DET_injector_harness_1__78289.144264
https://www.sau.com.au/forums/topic/461337-rb25-injector-harness-to-rb26dett/
You are going to put RB25 injectors in your GTR? Why don't you just get a new RB26 injector loom?
What kind of injectors - apart from the Neo they are all sidefeed.
And for the record I can't see it working.
The rb26 do not have the subharness like the rb25, the inj connectors are the same and i am not using a rb25 inj, i am using an xspurt 2k.
I need to change my fuel injector harness due to it dry rotting, the sheathing is getting brittle. The lenght of the harness is long enough to make a cut and put a connector on the maon harness.
If you have aftermarket injectors, does that mean you are going to cut the old harness out, fit a plug to the engine side, buy the new sub-harness, fit that then fit injector connector adapters?
If so why not just make the harness yourself and fit plugs that will go straight onto the injectors you have?
Otherwise, to me, it seems a bit silly. Your going to have plugs everywhere when you could have made it nice and neat
my wires for the rb26dett injectors are dry rotting and needed to be replaced, I am going to use the rb25 fuel injector harness to replace it [ drop resistor deleted in the process ] by adding a connector to the rb26dett harness.
The aftermarket injectors I am using , use the same connector as the rb's .
This thread makes no sense
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
