I assume you have the standard 320mm brakes Nick?
I do indeed mate... With the twin piston calipers. Not like the 350GT Sedan which came with a 330mm disc, but only single piston calipers.
  • 4 weeks later...
  • 2 months later...
What parts? Discs? Pads? Both?
You didn't take a wheel off and take some measurements to double check? I always do that on the first purchase when it's something that's not as commonplace as a Fa(i)lcon or Bomb-o-dore.
If there's one thing I learned as a student from my first boss in the broadcast business, it was "measure twice, cut once". Now you've learned the same.
You are right. The 330mm discs were for the older beasts whereas the 2009 sedan got the 320mm instead. The only theory why I suspect 330mm might still be an indicator is because in the US, the base model coupe had the larger 330mm discs in their 2009 model but the sedan still got the 320mm. That's not to say that their years lined up with the JDM spec though. Unless I got the wrong information, I found that my 2009 model, though built in Dec 2008, was released as a 2010 model in the US.
Problem is, I'm trying to look up the current DBA catalogue for further confirmation of numbers but they've severely trimmed down the Infiniti options and there's not as much detail as there used to be. It only lists the sports package, which is 355mm front and 350mm rear - that's what I have on my coupe.
It's odd, given that DBA still list discs for the G35/V35 but cut down the G37/V36 to just the sports package size in their catalogue. Curious stuff.
Edited by The Max
Well I assumed they are 320mm as ordered... will double check tonight. Mechanic didn't say; just said they don't fit.
Clearly I put too much faith in people who I assume should know this stuff. To be fair I guess they're a hard car to get parts for.
So frustrating
So frustrating
Ask him to measure that the disc rotor on the car so you know what to buy next.
It's just a matter of doing the homework. I've given up on trying to track down the older DBA catalogues I thought I had on file. Here's what I've found in the 2010 G37 Sedan workshop manual http://www.nicoclub.com/FSM/G37/Sedan/2010/BR.pdf (Nov 2009 revision of the manual itself):
  • Front Caliper 2 Piston and Rear Caliper 1 Piston type:
    • Front rotor outer diameter - 320mm x 28mm
    • Rear rotor outer diameter - 308mm x 16mm
  • Front Caliper 4 Piston and Rear Caliper 2 Piston type (in other words, the sports model):
    • Front rotor outer diameter - 355 x 32mm
    • Rear rotor outer diameter - 350 x 20mm
Again, it's worth taking the time to take a wheel off and measure it for yourself to confirm or get your mechanic to measure it up for you while he's at it but it's safe to say that if your mechanic said they don't fit, the discs you got in were too big.
Edited by The Max
Screw that! I've always been a firm believer in people helping themselves and if they do end up slipping in their own shit, then I'll step in to help out, knowing that they tried.
This is why, I might be a search-Nazi when people ask the same question over and over again but I do practise what I preach.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
