Hi all need some help. Car is r33 with many aftermarket arms/ suspension bits and tires are mid way through their life. I just got an allignment also. When i brake from mid to high speed with mid to high force i get very noticable shaking from the front.
What, specifically, could be the cause of this? Ie exactly what parts/conditions could cause this?
Thanks
What is an upper spindle bearing? Oh and front left wheel bearing was replaced recently
Picture your front suspension in your mind. Think about which bits have to rotate with respect to which other bits, particularly when steering. The upper spindle bearing is at the top of the spindle, permitting rotation around a (near) vertical axis.
Ahh, so the bearing which would attatch at the top of the knuckle? Thats a pain if its the problem. Would that be one which a shop would have to press out, same as a wheel bearing?
Could it be tyre related? Quick check is to rotate front wheels to rear.
When I flat spotted my tyres (cold tyres with no ABS at the track) it caused huge vibrations when braking.
The latest. After getting screwed around initially with the alignment by shop A, I took it to Pedders who were able to see that Shop A had aligned my car with caster settings of 3 and 10 to get it straight. Quite different from the 6 each side I asked for.
Pedders then showed me that it looks like the LCA bushes may be stuffed (as are the steering rack ones, they saw) as there was clearly something wrong from 1 side to the other there. I will investigate over the weekend, and its booked in with them for further investigation.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
