After a couple hours search I am unable to find a definant answer. My fresh 25/30 engine of roughly 6000km is starting to breath with hard street driving. Engine has a nitto pump, 1.5mm with the other blocked, returnes enlarged, sump vented to valve cover, running fuchs 25-60 oil.
My main question is, I'm not running vct but have done the internal mod todo so, and have blocked the vct oil drain. Now, does the vct oil drain, ONLY drain oil from the vct feed?
Cheers lads
https://www.sau.com.au/forums/topic/461621-vct-oil-feed-effect-pooling-in-head/
Sump vented to valve cover is the problem. Read the last half or or so of the oil control thread. Also in my opinion your oil is way too heavy. What oil pressure are you seeing?
Sump breather is t'd to the valve cover fitting, so basicly bypassed the valve cover and goes straight to the catch can. Il have a read of the tread.
Roughly tops 90 psi as the pump still has both springs.
I have always thought the 25-60 is very thick but a reputable rb tuner in my area swears by it. Probably so thick it won't drain back quick enough.
OK straight to catch can is fine. So when you say its starting to breathe what do you mean? Where is the problem evident? I use Motul 5W40 .
Can't answer your question about the vct oil drain - have you got a Neo head and why isn't the vct working? Why have you blocked the drain?
Pushing probably 300ml of oil after a few short full throttle runs. Non neo head. My engine was just never tuned with vct as the tuner was not aware it was functional. I figured it would be easier to block then run a hose if it wasn't in use.
I'm thinking a lighter oil, plumb up the vct drain and see how it goes.
I was more interested to hear if the vct drain had any impact on pooling.
Cheers.
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
