Its killing me having to work overseas at present. Its been so long since i have done a track day in my car. Need to get back and start pumping up the weekends away like the early years, problem is most people have kids now and cant get leave passes for the weekends :blush:
SAU Nickname: ssxricho
Car Make and Model: R33 GTST
Circuit Name: Winton Long
Lap time: 1:40.75
Circuit Name: Winton Short
Lap time: 1:10.69
Circuit Name: Sandown
Lap time: 1:28.38
Circuit Name: PI
Lap time: 1:57.00
Circuit Name: Calder
Lap time: 1.08.63
Modifications
Engine: standard ing, standard pump, unopened engine, highflow, pfc, exhaust, intercooler, pod etc
Power: 200rwkw @ 14psi
Suspension: greddy type s, sway bars
Tyres: 595rs or ku36 (both street tyres)
Brakes: standard or 324mm rotors
Body weight: standard, maybe a little heavier
What tyres were you running?
Very 2nd hand RE55's
Come on Roy give us family men a break...those MS weekends away are the only sane weekend I get these days :bunny:
How can they have up so mcuh in the space of 3 years. Teh yen exchange rate is about the same, the tyres are old hat nothing new in the way of compounds. FARKING RIDICULOUS! LOL , i need to find some 16X9" rims
Couldn't agree more Roy!! The manufacturer's reasons for the price rise doesn't quite equate to the actual dollar increase if you get my drift. Oh well I suppose someone has to pay for their F1 campain and advertizing :P
Duncan - I'm not actually convinced the Advan 050 Medium is a medium in the Dunlop sense if that makes sense. Guys are getting great wear rates out of them so I reckon they are just called a Medium in comparison to the A048's - which were HARD.
It's probably why that compund comes in Medium, Soft and Super Soft rather than Hard, Medium and Soft.
I'm going to give the A050's a crack next as I the reports I've had are that they are harder / longer lasting than the Dunlop R compounds despite being called a medium. Because given the medium is the hardest compound the tyre gets made in what is the reference point? It's all just marketing rather than a base figure probably.
New member here and only started track work this Feb at Winton. Still suck at driving but here's my times :blush:
SAU Nickname: Nurb608
Car Make and Model: Astra VXR
Circuit Name: Winton Long Track
Lap time: 1:49.1330
Modifications
Engine: 2lt turbo
Power: 174kwatw
Suspension: Stock Shocks, Custom Springs
Tyres: Dunlop Sport Maxx
Brakes: AP 4 pot
Body weight: 1350kg roughly
Circuit Name: Calder National Circuit
Lap time: 1:11.2491
Modifications
Engine: 2lt turbo
Power: 174kwatw
Tyres: KU36
Brakes: AP 4 pot
Body weight: 1300kg roughly
Cool, any vids of the lil Astra doing its thing....thats a fair wack of grunt at the wheels. Are they easy to get that sort of power from?
I've got a really bad video taken by the missus at calder from the weekend, i'll have to get it loaded up.
Takes alot to get power out of an astra as no one over here makes the stuff so I have to import it all pretty much. If only i didn't like opels, it would be so much cheaper :blush:
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
