Rb25 Speed Sensor Ecu Wiring
The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 😐
If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
By soviet_merlin · Posted
You put the driver's seat on the wrong side! Incredible detail on all of this. It looks like you could learn a lot about the car just from assembling the kit. -
I made a mistake today. I had a spot I fixed, and used guide coat and I kept sanding until it went away and it did (sort of), the guide coat was still there if I used wax and grease remover but was gone if I just blew the dust off. I ended up removing all of the filler and can feel a dip lol. The weird thing was I could still feel something after removing the guidecoat when the filler was there. Is the proper way to check that all guide coat has been removed is to use the wax and grease remover or is just dusting it off fine?
