  • Replies 135
Yes Mallala only open the last straight before the small chicane onto the main straight for drift....kinda too small if ya ask me. Pt Gwaler go-kart track was the ultimate drift track...if your into that sort of thing :)
Im still getting my car sorted (steering-tie rod ends,rack rubbers, 4 wheel align., rear camber kit, bigger front brakes...) It needs a quick retune at wot, but will try to see if i can get it out on the track. Would be great to open it up and enjoy the top end properly for once :)
Interesting to see when the forums came back Troy, your user title changed to RB30ET...lol...message in disguise? ;)
Rowdy has had certain problems relating to every panel on his car beign bent, so that a pretty good reason...other then that who knows, ill lay the hard word on him :D
He has 2 x GTR's and 1 x GTST, surely at least one of them is on the road, anyways I'll whinge at him directly as well. :)
come back to adelaide Troy, and ill give u a squirt in my car....so you can tell me what else needs fixing :)
If its running then it doesnt need anything, Nissans are just fancy Datsuns, they may get loud, oily, and scrappoy, perhaps even slower, bu they never NEED fixing as such...well mine doesnt anyway :rolleyes:
have to say that aint true, you slide wherever you want.
you can do the whole track.
how long ago did you last got out?
A while ago now...they had em lined up at the back straight. Then they let em go out, and they did do most of the track, but from spectators pov its pretty sheit, as you cant see 9/10ths of the track...
Pt. Gawler is a much better track imho
There's a drift being organised there for the 29th of next month over on NS.com
No way, Pt Gawler is Shithouse, way too small, think of how fast sliders are taking turn 1 at Mallala.......Pt Gawler is just a controlled burnout over the whole track. It was all good when people first started to get an idea on how to use the handbrake.
