Hey all
Recently my brother has bought a R31 station wagon.
Started its life as a non turbo, but has been converted on the same non turbo block to a turbo.
does it have to go through regency now?
Can i just tell motor reg its now a turbo?
Will the insurance company be ok with it being a turbo?
cheers
https://www.sau.com.au/forums/topic/462387-legality/
I was surprised about a year ago when I found that SA Transport webpage does now list guidelines on modifications, and what is and isn't illegal. For this particular change - adding a turbocharger:
https://www.sa.gov.au/topics/transport-travel-and-motoring/motoring/vehicles-and-registration/vehicle-standards-and-modifications/aftermarket-components
Turbo-charging/supercharging petrol engine vehicles
Turbo-charging or supercharging an engine increases the power of the engine and may increase the exhaust emissions, fuel consumption and reduce the service life of the engine.
Passenger cars and passenger car derivatives (car type utilities and panel vans) manufactured prior to 1 July 1976 and fitted with petrol engines can be fitted with a turbocharger or supercharger to the original manufacturer's engine without DPTI approval.
For cars manufactured on or after 1 July 1976 the fitting of a turbocharger or supercharger requires one of the following:
  • the vehicle is fitted with a Second Manufacturer's plate to demonstrate compliance with all Australian Design Rules
  • the vehicle to pass an IM240 emissions test
  • the converted vehicle is identical to the production turbo/supercharged vehicle.
In all cases a statement of requirements is required and the vehicle must pass a roadworthiness inspection.
Certification from a professional engineer may also be required. See list of qualified engineers recognised by DPTI - MR426 Chartered Professional Engineers 409.4 KB .
I'd imagine these sorts of engineering changes would include checking over whether the brakes are adequate, any changes to the fueling system are within specifications, that adequate exhaust & emissions systems are in-place, etc.
https://www.sau.com.au/forums/topic/462387-legality/#findComment-7670660
I thought the general consensus with these cars was to keep N/A's that way, as they're then still P-plate legal, and those are in-demand. Also - the cost, engineering, legalities, and extra police attention of a converted car (and they're probably worth less than a factory turbo, or plain N/A) making it generally better to just buy the turbo car instead.
https://www.sau.com.au/forums/topic/462387-legality/#findComment-7677510
Yes, i thought so too. But people still want to do it for some reason..
I guess for them its not about the money or the legalities its about the project, and they can then complain about the whole process and unwanted attention.
https://www.sau.com.au/forums/topic/462387-legality/#findComment-7677574
Only makes sense if u have a wreck that u got for fu*k all with all the required parts to raid. Still lots of work though. I still wouldn't do but each to their own.
https://www.sau.com.au/forums/topic/462387-legality/#findComment-7677602
Ya I understand what you guys are saying iv had my car for 6 years since on my L's and know that I can drive a turbo I was going to turbo it it more because I have spent a lot of money on it makeing it look they why I want it to look and have growin a attach meant to it and don't think I could sell it I pretty much have all the stock parts to turbo it so know it almost time to take it to the machines to get down
https://www.sau.com.au/forums/topic/462387-legality/#findComment-7678018
    • If your tuner can't make the car idle like factory, I'd get a new tuner. These injectors are fantastic and I'd have very serious concerns about a tuners skill set if they couldn't get them to idle well.
    • It's highly likely you will find something. Alternatively, a quick design and order online from chaina and you'll have a perfect solution
    • Idle Lambda target is off by .4 but I reckon the VE table is not correct. If my tuner has no issue using these injectors I will keep them, they are good quality after all
    • I already have an Apexi. Just wondering if it is worth putting in something new since the Apexi is likely well over 10 years old, if not 15. I know the injectors work but they already run at less than rated fuel pressure to make them work properly and idle is basically 1% duty cycle or less. Could be better
    • Nice, I would never have thought in that direction. The actual motor is a cylinder....I wonder if there are any cylindrical heat sinks with the right ID  (and if there is clearance to other components). I think adding airflow is still a thing as well....will check it all out next time it is in the air. Wish I had a hoist...
