Hello all,
Just recently got my R33 back after a serious short circuit fried my PowerFC and CAS, caused assumedly by an earth from the motor being improperly placed on the alternator. So now I'm paranoid and want to go around and check all my earths but days of googling still has me stumped as to locations, so if any whizz out there could let me know where any/all earths are or should be on a series 2 R33 you will get the love and gratitude of a hairy dude on the internet
Thanks in advance!
https://www.sau.com.au/forums/topic/462522-r33-earth-locations/
  • 6 years later...
The diagrams are good but visual pictures would help best. Can anybody please show pictures of where exactly the engine body earth cable is bolted to? Also it appears the alternator has one earth connected to it also, but where does the other end go to?
Sure. I'm an anybody.
I've included some handy colour coded arrows to assist with your enquiry.
Red = engine body earth cable
Yellow = alternator ground wire.
In the pictures you can see that the engine body earth cable and alternator ground wire both connect at the same point, they are stacked. The same way the wiring diagram shows that they are stacked.
Now when looking at the pictures, don't be distracted by the fuel filter. It is fkn sexy, but focus on the arrows and the ground wire. Also the Kryptalon fuel lines are pretty sexy too, don't be distracted by that either.
If you need any more pictures of my engine by, you can hit up my onlyfans account.
  • Like 4
Buddy you're just the best!!! It took me awhile to see the arrows because I was focusing on those sexy fuel lines and filter setup 🤭
Also @GTSBoy I realize you're making a snide joke but in my case I am missing the ENTIRE section of that loom, so I don't have the alternator-starter-transmission harness to even trace wires. That's why I needed to see a visual indication of the OEM locations since I will be building that part of the loom from scratch and last thing I want is to start a fire.
So just to recap, it seems the grounds on a stock 25DET 33 are as follows:
1. Engine block (near dipstick) to chassis rail.
2. Alternator to chassis rail (same point as above)
3. 2x next to the coolant temp sensors at water outlet.
4. Passenger side strut tower to exhaust manifold
5. One earth cable at the back of the motor
6. One earth cable near left headlight
7. One earth cable near right headlight
It's much clearer now. Thanks guys!
  • Like 1
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
