Hey guys,
As the subject suggests, just wanted to ask if you experiencing something similar. I understand its a 20+ year old car but want to know if mine is just extra tired or others have similar problem.
When doing hill runs and generally under heavy steering, taking corners and the likes, the doors start squeaking...
Any input appreciated.
Thanks
Its probably combo of two as dors are sitting bit off and clank when you go to shut them, then offcoarse theres chassis twisting bit. Rear sway bar should help? Don't have one atm....
Open a door, grab the top and bottom and try to move it up and down. If you hear a clunk or if there is any movement then you need new pins and probably hinges. If you get no movement at all then it is in the door brackets, try loosening them, repositioning [you only get a little bit of movement], and retightening. Haven't done Skyline doors before though.........but it should be similar.
  • Like 1
There's always the chance she's had repair work to the body, but……..
The coupe is a very flimsy body. Jack her up at one front corner and check how the doors open/shut. You may not be able to actually open them.
Slam a door and note the scuttle shake, only the ¼ window is holding it together.
I don't see a rear tower strut doing a lot, it takes a cage to get any stiffness in these chassis.
Thanks for your inputs guys, car has been looked over for me after the purchase and no signs of repair or previous accidents been found, not to say something may have been overlooked.
Mainly I was wondering if it was something common for the car or not...? Seems not.
Will definitely check on the door brackets etc and see if I can see where flimsiness comes from.
Cheers for all your input and suggestions. :)
My drivers door squeaks and it is irritating. As others have suggested, a slight twist in the chassis will do it as will the door having dropped slightly.
In my case the actual sqeak is the window rubbing against the rubber seal as the door is pillarless.
The door, hinges, chassis and rubber seals are 25 years old so for that age I would think it quite common.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
