Hey guys, I did a compression test on my RB25det neo. What do yous think?
Dry:
Cylinder 1 - 145psi
Cylinder 2 - 147 psi
Cylinder 3 - 152 psi
Cylinder 4 - 150 psi
Cylinder 5 - 150 psi
Cylinder 6 - 154 psi
Wet:
Cylinder 1 - 182 psi
Cylinder 2 - 180 psi
Cylinder 3 - 180 psi
Cylinder 4 - 175 psi
Cylinder 5 - 185 psi
Cylinder 6 - 180 psi
Couple of months back, my car use to only blow white smoke on boost/acceleration. Then after a while it was getting a lot of knock, like 160+ on my power fc hand controller, but only while on boost. It was fine driving normal and I only boosted it every now and then to see if it'll still knock after changing some things, hoping it would have stopped knocking.... but it didn't. So I stopped driving my car altogether to prevent any further damage I could be doing.
And now when I turn my car on it constantly blows light blue smoke while idling or driving. I take my car for a little drive around my complex evey 2 weeks or so. I haven't boosted it but I'm guessing it'll be knocking and smoking even more than before.
Any thoughts? Thanks for reading.
https://www.sau.com.au/forums/topic/463039-thoughts-on-compression-test/
The compression results seem reasonable for the age of engine. The variation isn't drastic at all. Not sure what is causing your smoking issues. I take it the fc is running the apexi maps. You shouldn't be putting it under max load when its untuned, especially since it was registering such a high knock count.
The car was tuned by previous owner at mercury motorsports. Only started smoking and getting high knock at boost mid last year. I've bought a standard rb25 turbo in good condition and will put it in when I get time. Car still drives fine when I do drive it. Just the smoke and knocking.
The car is burning oil and I'm guessing this is why it's knocking? If the turbo doesn't fix the smoke and knock, I'll probably have to pull the head out and have a look inside the engine.
Anything else I should and or shouldent be doing?
Yes. I believe you should firstly stop driving the car until you fix this oil leak and then get it to a tuner asap.
To add to my other post. Yes you are probably experiencing detonation or pinging. That's probably why your engine light is flashing on boost
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
