Hey guys, I did a compression test on my RB25det neo. What do yous think?
Dry:
Cylinder 1 - 145psi
Cylinder 2 - 147 psi
Cylinder 3 - 152 psi
Cylinder 4 - 150 psi
Cylinder 5 - 150 psi
Cylinder 6 - 154 psi
Wet:
Cylinder 1 - 182 psi
Cylinder 2 - 180 psi
Cylinder 3 - 180 psi
Cylinder 4 - 175 psi
Cylinder 5 - 185 psi
Cylinder 6 - 180 psi
Couple of months back, my car use to only blow white smoke on boost/acceleration. Then after a while it was getting a lot of knock, like 160+ on my power fc hand controller, but only while on boost. It was fine driving normal and I only boosted it every now and then to see if it'll still knock after changing some things, hoping it would have stopped knocking.... but it didn't. So I stopped driving my car altogether to prevent any further damage I could be doing.
And now when I turn my car on it constantly blows light blue smoke while idling or driving. I take my car for a little drive around my complex evey 2 weeks or so. I haven't boosted it but I'm guessing it'll be knocking and smoking even more than before.
Any thoughts? Thanks for reading.
https://www.sau.com.au/forums/topic/463039-thoughts-on-compression-test/
The compression results seem reasonable for the age of engine. The variation isn't drastic at all. Not sure what is causing your smoking issues. I take it the fc is running the apexi maps. You shouldn't be putting it under max load when its untuned, especially since it was registering such a high knock count.
The car was tuned by previous owner at mercury motorsports. Only started smoking and getting high knock at boost mid last year. I've bought a standard rb25 turbo in good condition and will put it in when I get time. Car still drives fine when I do drive it. Just the smoke and knocking.
The car is burning oil and I'm guessing this is why it's knocking? If the turbo doesn't fix the smoke and knock, I'll probably have to pull the head out and have a look inside the engine.
Anything else I should and or shouldent be doing?
Yes. I believe you should firstly stop driving the car until you fix this oil leak and then get it to a tuner asap.
To add to my other post. Yes you are probably experiencing detonation or pinging. That's probably why your engine light is flashing on boost
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
