Hi all,
I have a few items up for sale:
R32 GT-R OEM Rear Brakes
Price: $150.00 (pick up in Melbourne or post at buyers expense)
Reason for sale: upgraded to Alpha Omega Racing Brembo Brake Kit
NOTE:
  • The pads will need to be replaced
Garrett Boost Gauge
Price: $50.00 (pick up in Melbourne or post at buyers expense)
Reason for sale: This was mounted in the drivers' side circular vent and I want to reinstate the air vent and don't have a need for the gauge
NOTE:
  • What you see is what you get. I.e. this is the boost gauge, mounting bracket and cowl only. No other wiring etc. is included.
  • If you have an R32 OEM drivers' side circular vent and you are looking to sell it or swap for this item, I would be keen if it is in excellent / very good condition.
R32 Centre Air Vent
Price: $15.00 (pick up in Melbourne or post at buyers expense)
Reason for sale: replaced with new item
NOTE:
  • I replaced this item in my car as the vertical control on the drivers side of this vent is broken so the vent slats fall down.
  • This may suit someone who can repair this sort of thing or if yours is even worse
  • Nissan Part No. 68750-01U00
Please PM for further details.
Also available on other For Sale Posts:
HKS GT-RS Twin Turbos $1400.00 (make an offer)
R32 GT-R OEM Front Indicators: $150.00 firm
Cheers
Rob
  • Like 1
  • 1 month later...
  • 3 weeks later...
  • 3 months later...
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
