I went from NM35 (2.5Lt 250t RS Four) to PNM35 (3.5L N/A 350RX Four).
Theres a power graph on here somewhere here that shows the 3.5 NA vs the 2.5 Turbo. The 3.5 has more top and bottom end, the 2.5T has more midrange.
Yep. Both behave differently, but at stock levels there isn't a ton of difference in straight line performance.
Of course, once intake, HFC and exhaust mods are on the 250t is obviously quicker and the powerband changes but the 3.5 is certainly no slouch.
What I do find interesting is that the whilst the 3.5 is much, much, much more useful putting around under 3000rpm (it really wakes up north of 3500-4000rpm - adding 370z/V36/G37 headers really help build the revs), my 250t was outputting more torque at 3000rpm than my 350rx does.
Performance aside, there is nothing that was inferior on the series 2. Overall, the series 2 is a much nicer car to drive and to own. Also, performance upgrades are incredibly easy to acquire if you are that way inclined.
Of course, if you are referring to going from the VQ25det NM35 to the VQ25dd engine in an M35... you will be disappointed.
https://www.sau.com.au/forums/topic/463234-nm35-to-m35/#findComment-7690426
lolz Cam!!!!......good stock NM35's with the VQ25det have been know to run low 14's with no mod's whatsoever!!! Never seen a stock PM35 get close to that out of the box....14.8/9 was the number I think for PM's...and by no means do they feel as strong up top as the NM35's. HP is about the same in the peaks....its the torque that push's the NM35's along a little better all the way to about 5,800rpm's...no need to rev em after that when stock.....unlike the PM35!
However the guy above is right in terms of refinement....the PM35 is imo a much better all round car in stock form. It comes around to whether you want to mod or not. If you do then the NM35 is the better choice as the end result is much greater as there "are" more choices in setups for any particular person now.....maybe not in the past....but Def now and moving forward.
https://www.sau.com.au/forums/topic/463234-nm35-to-m35/#findComment-7691060
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
