All parts are located in Padstow, Sydney. Shipping will be paid by the buyer.
Contact me via PM.
Item: -5 turbo's with modified actuators by Racepace Motorsport. Currently set at 19 psi. Turbine housings have been opened up to match the gasket. Comes with oil drains also.
Price: $1200
Condition: Great. 10,000 kms worth of use.
A62CF78A-9D5E-4A21-B915-659918E91D9B_zps
93CC027B-E781-4D96-9C57-1E185065EAC7_zps
ECFFBDD1-322B-499B-965A-1FBB7539A9B0_zps
Item: -5 turbo's. Both are blown so will suit a GTX upgrade.
Price: $500
Condition: Dead. Needs rebuild.
4186408A-C43E-4298-9C5C-72F29AFB5387_zps
0F0D2189-0135-4D2F-BAAC-6C29D293608A_zps
3720BC68-0976-417D-947B-E7DB6FB8182D_zps
Item: Front pipe to suit RB30/26. Twin 3 inch into single 4 inch
Price: $300
Condition: Fine
12245609-C229-4D06-85E4-B41B6835E05D_zps
AFB65AB2-E7AE-4060-BCB4-455EDCD1B8D8_zps
Item: SMB rear muffler "diff back". Single 4 inch into twin 3 inch tips.
Price: $350
Condition: Fine.
40E9D4AB-EB99-45F0-A4EA-FEFF234E508E_zps
DDAED056-E301-423A-B944-6F174B8CF92C_zps
C54C0B9C-A742-4437-B470-264EAB74ACBA_zps
Item: Modified Twin Turbo Pipe
Price: $150
Condition: Fine. It has had the "twin turbo" raised bit ground down. It came off an RB30.
C333F06B-AFD9-41D3-AF8A-AC7FAEC6D64D_zps
0F163E90-1B82-4700-8D7B-676058B5FC03_zps
Item: HKS AFM delete pipes
Price: $200
Condition: Fine. Painted black. A few scratches.
17A012C5-47B4-4974-8C9D-B7114A4F5CFE_zps
Item: Modified intake pipes. This has had the narrow point removed.
Price: $100
Condition: Fine.
0EAD7EF7-9879-4F31-98C7-7EB95ACE4536_zps
D4987FF0-9F8B-4228-A9F4-99AB4425B23B_zps
8919EACA-99AB-4963-8649-3E53850B841E_zps
B28C02FA-A457-4989-B9B8-4D21121D1E04_zps
Item: HPI RB26 dump pipes (32/33)
Price: $500
Condition: Fine
1872BBB9-4F24-421F-A3A3-79D59D330C5D_zps
  • 2 months later...
Hey guys,
Both items are located in Georges Hall, Sydney. Buyer pays postage. Contact me via PM.
Item 1: Haltech EGT sensors (6 of) includes weld on bungs
Price: $600
Condition: Brand new.
FC1C1675-C431-4CE1-AC12-BEBBF63D8300_zps
FE6A7E0D-85D3-4D80-855B-7DE9DBF6794E_zps
1EC7A066-BA6E-4F0D-B98A-EA797144B689_zps
Item 2: Holley Dominator 12 - 1800
Price: $420
Condition: 2 weeks of use and 1 dyno session. It came out of GTRNUR's (Ian) car. 98 fuel only.
27D85DE6-CDA9-44AC-A2B7-6B002E66EA3B_zps
62AF46C6-3F90-4B55-B353-910C8C45D63C_zps
  • Like 1
  • 4 months later...
  • 3 weeks later...
  • 4 weeks later...
