Hi Guys,
I finally had my car on the Dyno today.
Im a little dissapointed to be honest, I thought it would be a bit better than this.
Car is an R34 GTT
3 inch Exahust turbo back
Trust Pod filter
Greddy Front mount intercooler
E-Boost at 9psi
Rest is stock.
As you can see from the dyno pic there is horrible stuff happening to the power curve.
Im lead to belive that is caused by the stock computer getting upset at 9psi of boost. This sound right?
Im getting a Apexi Power FC installed in a few weeks.
Boost will be incresed then too. Whats a safe level btw? (Ive been told 12 to 14psi).
Anyone want to hazard a guess at what improvment I should see?
Any suggestions on what else to do?
Yeah Bill... You weren't being lied to.
The stock GTS-t/GT-t ECU has a boost cut at 10psi-ish where it retards the timing to protect the engine as it thinks something is wrong and the car is overboosting.
A PowerFC will give you a MUCH nicer power curve... Here's what happened to mine:
BLUE LINE: Standard ECU with 0.9 bar boost
PINK LINE: Power FC with 0.9 bar boost
As Merlis said, you have hit the dreaded Skyline overboost protection. All is good with PFC fitted and tuned. You will pick up the usual 25 rwkw max power and about 40 rwkw average power. :P
PS; get them to do the dyno in 4th gear next time, makes it easier for my poor brain to work out engine rpm. :P
Not entirely sure what each individual abbreviation means but as I understand it, Shoot Out Mode locks certain variables such as ramp rate and drive train inertia settings and calculates the power level based on a benchmark 'standard day'. It does however list the atmospheric and ramp conditions to aid comparison with charts produced elsewhere.
I guess some of the abbrev's would be ramp rates, air temps, barometric pressure etc etc...
Adrian
is the std ecu boost cut for a gtst 10psi??? i thought it was 12psi?
is there are difference between s1 and s2 r33 gtst and r34 gtt for that matter as s2 gtst and r34 gtt have those plastic impeller baldes and what not which ppl say that cant be boosted as much as the ceramic one even though it is ulitmately the same almost...
anyway i got s1 r33 and thought the boost cut was at 12psi, thats all....
Just to clear somthing up here. The ECU doesn't read the boost pressure correct? It caculates it from Air flow. So it is possable to hit boost cut with out running alot of boost say if you put a larger turbo and IC on. I know I have hit the cut in my car at 9 PSI.
Yep, you are correct USRB,
It is an airflow cut, not boost cut technically. Sydneykid has corrected my terminology on this many times, lol.
Thats why you would hit your " boost cut " earlier on a cold day, with full load of passengers, with a bigger turbo, etc etc.
The ecu does not go into this mode from a manifold pressure signal, it will perform this " cut " or " overboost protection " as a direct result from signals sent from the air flow meter.
Bill.
Don't be dissappointed.
I made about the same with very similar mods.
I had 162 with unshielded pod, bleed valve just before boost cut, full exhaust (excluding dump).
I now have a big intercooler, but that big dip is exactly what I get too. It sucks.
I'm about to get A PowerFC fitted thought, so happy days for me.
The more mods you do, the worse the dip.
Get it tuned out.
BASS OUT
I don't mean to knock you so don't take it personally, but isn't that power figure really Poor?
I mean I got a similar figure when I had my R32 with an exhaust, filter, rb25 turbo and 11psi..
and alot of guys get over 160rwkw with stock rb20 turbo..
surely this is not normal for an R34 GTT
unless it's auto.. maybe?
GTST
Problem being that each dyno is slightly different, sometimes significantly different.
I clocked 155rwkw on one dyno, then 126 on another, then wound the boost up and made 162 on a dyno similar dyno to the 126 reading one.
If you extrapolate the above figures you could come up with the following.
155/126 = 1.23 (different between dyno readings)
then 162 x 1.23 =199.26 (taking modded car back to first dyno)
So you could say that I have 199 rwkw if I went to the right dyno........
It's all reletive.
Look at my sig and the quarter mile time, and that should give you a better idea as to the cars grunt.
BASS OUT
yeah the results with the power fc are good, where can you get these from and what is it that they do ?
Pete,
PowerFCs are a stand alone computer which plug straight in where your factory comp is. They run everying including air con etc... They get rid of your speed limiter, boost cut and so on and run much smoother over all. They'll generally cost between $200 and $400 to tune on a dyno with standard mods but they're about the best you can get of the money. Just had mine put in and am pretty happy with it.
This link is about the cheapest place you'll find them:
http://www.nengun.com/index.php?cPath=38_2...14e1fa8438ddc03
I bought some other bits from here a couple of months ago and they usually deliver within a week.
Good luck.
Adam
Let's clear something up here, R32 GTST, R32 GTR, R33 GTST, R33 GTR and R34 GTT all have ceramic turbines. R32 GTST, R32 GTR, R33 GTST, R33 GTR have steel compressor wheels. These turbos are made by Garrett for Nissan using Nissan tooling. Although I have seen a couple of late R33 GTST's with plastic compressor wheels. All R34 GTT's I have seen have plastic compresor wheels. These turbos are made by Hitachi for Nissan using Nissan tooling.
I have never seen a problem with the plastic compressor wheels, it's the ceramic turbines that are subject to failure at high boost and/or temperature.
The type of turbo fitted has nothing to do with the overboost protection, its dependant on the ECU. :P
A very stupid question, because I'm 99% sure the answer is 'no', but an S-AFC won't help will it? Or will it help smooth things out even though the stocker ECU will still be enabling the boost cut?
An SAFC may well help, ultimately it depends on the amount of airflow. An SAFC simply modifies the voltage from the AFM to the ECU. Generally increasing the boost (from std) causes RB25's to run rich. In order to lean out these excessively rich A/F ratios, the SAFC reduces the AFM voltage the ECU sees. This "tricks" the ECU into believing that the engine is using less airflow than it really is, so the ECU injects less fuel. Hence correcting (leaning out) the A/F ratios. :wassup:
In some cases optimising the A/F ratios requires lowering the AFM voltages below that which the ECU moves into over boost protection. So you don't get the big power "dip" at ~5,000rpm. There is a limit however, around 200 rwkw has been my experience, where the SAFC can't lower the voltages sufficiently and the "dip" returns. :thumbdwn:
The best answer is a Power FC (FC= Full Computer), no more dips then, at any power level. :P
Well, that suits me quite well... the current target is 200rwkw as cheaply (but as safely) as possible. I've cut corners by using a 34GTT intercooler, so if an SAFC can smooth out things up to 200rwkw, fine by me. :P
Thanks SK, excellent advice as always.
Edit: Additional stupid question... anyone know a good place in Sydney to get an SAFC fitted and tuned? I'm off on a driving holiday soon, and I've got some free time there...
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
