So I recently purchased a 92 R32 GTR and had it shipped to me. I was told it was mostly stock besides intake/exhaust. After getting the car I found that's not the case. So onto the problem, when the car makes boost it hold good up to 1 bar but after it goes over that it will cut out. the once or twice iv messed with it the make sure it wasn't a fluke the highest reading I saw was over 1.5 bar. I'm not sure if its cutting out because the fuel cannot keep up with the added requirement or if the boost is cutting out. I has the stock boost solenoid removed and both those lines cap'd off. So am i right to think it should be running off the turbo actuator pressure? When I rcvd the car it was also bone dry on fuel and i had to drive it on E to the local gas station. Maybe a clogged fuel filter?(already ordered a new one) any direction to look before I start ripping the engine apart would be great.
Side notes:
-The actuators look like they have been upgraded to HKS ones but the compressor housing still says garret
-I do know its not safe to run that much boost on stock turbos if they are stock.
Known mods:
HKS Actuators
HKS cam slider gears
Apex intake
Tomei Cat back
Some dumb hyper ground system
Stock boost solenoid delete(not sure about this)
Greddy boost gauge
Edited by Noc88
https://www.sau.com.au/forums/topic/464621-overboost-issue-r32-gtr/
step one - stop smashing that level of boost.
your gonna lean it out and kill it fast.
fuel blockage will not cause high boost, plumb the lines back into the actuators/ boost solenoid properly, if you don't know whats going on put it back to stock and get it right. it might just be bleeding to nowhere and free boosting
Edited by GH05T
I'm not retarded I only did it twice. first time testing the car and 2nd time making sure it wasn't a fluke.
I'v already started ripping it apart to go as stock as i can but it did not come with the stock boost solenoid so I'm just replacing vacuum lines and making sure they are properly clamped. Also I plan to test the turbo actuators while i have it apart.
  • Like 1
  • 3 weeks later...
Well Figured everything out. The over boost issue was improperly routed vacuum lines and after I correct them she started running on waste gate pressure. I have since installed a electronic boost controller also. The cutting out at high Rpm's was the combo of Coil packs and installing a smaller gaped spark plug. Thanks for the advice.
  • Like 1
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
