the problem was a little better but not fixed yet so i took my car to garage7 for an inspection
13262423_701977659944045_1879640653_o.jp
i got it baack and they said it has a faulty o2 sensor
after driving it around for a few days i opened up the bonnet finding that the o2 sensor wasnt plugged back in
https://www.sau.com.au/forums/topic/464851-r34-gt-daily/#findComment-7729552
i figured the head was blown and decided it would be better and cheaper to do a whole engine swap. theres a few reasons why i did this but summary was that the old motor just wasnt running right, was full of oil leaks and i needed to get a gear box rebuild anyway. the syncro in gear 2 was gone... so figured do it all at once.
i picked up a rb25de motor from jdm spares but soon after discovered that it was full of rust.
13249412_701994246609053_1115596271_n.jp
https://www.sau.com.au/forums/topic/464851-r34-gt-daily/#findComment-7729589
while waiting to get the gear box back i figured ill do some other things to the car. got some project mu break pads, slotted and drilled rotors, weather shields, short shiftier, cusco coilovers, all new belts and gaskets and much more.
after taking the exhaust off i realised that one of the bolts of the cat had snapped and the flanges had been welded together, but the weld was broken which explains why the 34 was so loud.
https://www.sau.com.au/forums/topic/464851-r34-gt-daily/#findComment-7729634
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
