Hi guys i posted up a thread about trying to find an importer/exporter to get one fo these over to the uk but its actually easier for me to just sort out all the shipping myself, so im now just looking for somebody with a series 2 rb30e engine or block needs to be in good condition, well only the crank needs to be good as forged pistons and rods will be going in.
All id need from the person is them to strap it down to a pallet for me and drain the oil and water out if its a complete engine :)
thanks Mike
https://www.sau.com.au/forums/topic/464948-rb30e-blockengine/
Yeah this does seem to be the case. I've also been offered a short motor for 330 and a complete engine for 100. The complete engine has been in storage for 5 years though but I'm assured it was a runner before it got put in storage
just a quick bump as im after a bit of advice i have seen tons and tons of threads about people asking the difference between the holden and nissan rb30 blocks and the answer is always nothing the only difference comes from what year the block was amde ie if it is a series 2 or series 1, but i find people are always talking about the r31 skyline or the vl, my question lies with the patrol block which is called a rb30s not a rb30e i know this is because it is a carb engine not electronic fuel but are there any other differences, mainly in the block? like different pistons? compression? or is it the same aslong as its a series 2 ofc
thanks Mike
The "series 1" RB30 blocks don't have the bungs for oil and water lines. The rest do. Everything else is pretty much the same (VL turbo engines have lower compression).
Not sure on the Patrol block but I'd imagine they're the same as series 1.
Well if you're not going to use the bungs on the block, it wouldn't matter which series you get.
Ask the seller for pictures, look for this:
http://wiki.r31skylineclub.com/index.php/Turbocharging#Connections_To_Block
It's a series 2 I'm after as im building a rb25/30 the seller has shown me pictures of all the bungs so I'm sure it's a series 2 block which is great. But the first thing I noticed was the sump is completely different to the vl and skyline ones and it just made me wonder what else might be different on a patrol rb30
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
