Hey Guys
I'm after a sunroof to suit an R32 GTST skyline. My current one leaks and is rusty so I desperately need a replacement.
Around Brisbane preferable, but can travel if need be. Also open to interstate sellers if your happy to ship via courier.
If you can help me out please PM me.
https://www.sau.com.au/forums/topic/466103-wanted-r32-gtst-type-m-sunroof/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
