 Hello guys I'm in the US
 Just wanted some input on building a high horsepower RB30/26
 Looking forward tips on what mods to do to the block the factory crank and so forth?
rb26 head is already built with tomie 270 10.80 lift. Tomie valve springs  and a port and polish
Parts I have for the block
nitto I beams with +625 arp bolts
Cp 8:5:1 rb30/26
acl main and rod bearings
tomie oil pump
https://www.sau.com.au/forums/topic/466193-building-a-1200hp-rb3026/
Contact Rips for bottom end bracing:  http://www.ripsracing.com/ Look into reinforcing the block with grout filling.
I presume this is for a drag car. I would have gone for at least 9:1 static CR but mainly you just need a massive turbo with perhaps a little NOS to get you going!
What is the car? If its AWD you'll need an adapter plate (also obtainable from RIPS).
Have you read the RB30 PDF in the RB30 section under "forced induction"?
Thanks for the reply, the car is gonna be for drag racing, it's gonna be tuned on e85, I have and adapter already for the awd... I'm am looking into filling the block with grout filling. Just really wanted to know if I need to drill out the mains and rods oil feed in the crank.
This, order the RIPS 1300hp motor, they know how to hold them together
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
