Juts buy my car, makes the same power has the right clutch already :):)
If you're an exedy fan boy, don't buy their Exedy HD range, it's rubbish. Make sure it's at least a Sports range and a above as the pressure plate is firstly made in Japan and secondly not re-manufactured rubbish sprayed a homo pink colour.
https://www.sau.com.au/forums/topic/466308-rb25det-clutch/#findComment-7767867
I'm only at 332kw atm, but i'v had the exedy twin plate for the last 6/7 years and haven't had any issues. I'm sure i'll have to replace it soon though, just wear and tear.
Apparently their twin can handle 500hp day in day out.
https://www.sau.com.au/forums/topic/466308-rb25det-clutch/#findComment-7767899
NPC do a good single plate that should just handle that power or they do a twin plate as well that im told is really good and feels almost like stock. My NPC clutch has been great. I had an Exedy HD cushion button years ago and it only handled 200rwkw for about 6 months so listen to above advise about exedy if you want to go down that path
NPC is good because of the local support
https://www.sau.com.au/forums/topic/466308-rb25det-clutch/#findComment-7767921
I can completely recommend a Nismo Coppermix twin - after getting one fitted to my car when I did the engine replacement I can safely say that I am extremely happy with it as is everyone else who has tried out the car.
Drives and feels like a stock clutch (infinitely better than the Xtreme clutch that was in it when I got it) but handles a whole lot more torque, the only real disadvantage it has compared its competition is the Nismo tax ($$$).
https://www.sau.com.au/forums/topic/466308-rb25det-clutch/#findComment-7768029
  • 3 weeks later...
    • Yea that's a fair assumption. I'm presuming they call them solid lifters as they have no moving parts like hydro lifters.
    • I believe you're confusing WMI with water injection. Looking at that graph, the 93aki+WMI car is making more power than C16 race gas. Boost juice, which is what I also run, is Snow Performances 50/50 premix.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
