Hi All,
Injector issue so time to change out.
Was using S15 side feeds which served their purposes well, sprung a leak.
Would rather purchase new as I have had a decent run out of them.
Looking at going JECs 550s or higher.
I know this widely debated but I don't want to go to a top feed rail.
Regardless I know I am up for a re-tune so was hoping to hear any recent feedback regarding them before I take the plunge.
Old reviews have a mixed bag of feedback regarding them.
https://www.sau.com.au/forums/topic/466513-jecs-side-feed-inj-for-rb25det/
I am in the same position as you being a 33 engine.
You are still looking at around $900+ for some 'decent' side feeds like nismo. You are looking at the same cost going topfeed, and the injectors are new tech.
"JECS" 550+ etc as far as i am aware are still highflow injectors. They market them as standard jecs, because that's what they are, jecs injectors... that have been highflowd.
Completely understand how they market them as Jecs and then they are high flowed etc, also understand that they are "oldish" technology, the same "oldish" technology that 33 owners were using 4-5+ years ago.
Considering I was running S15 side feeds I am hoping for recent feedback of any members who have recently installed / used and had them tuned.
As I am running a Nistune board I already anticipate a new tune will be on the cards also.
I upgraded to 550 Deatschwerkls which i believe are actually highflowed stockers and they work ok but I think you may be able to get the better new tech injectors to fit in the sidefeed set-up (not 100% on this) but check with Scotty.
I tried JECS 550's - it was shithouse. Tuner was so angry and the car just idled like a bush pig. I chucked the whole lot out and went top feed setup.
Take my word for it and don't waste your money on a side feed setup!
Were they second hand? Did they get cleaned/tested? Never seen trouble like that with jecs 550s, saying that if you're buying now go with top feeds for sure
I bought them of a club member, they were practically brand new. He had the original receipts and paperwork. He had bought them from a supplier in Perth who claimed they were flow matched within 2%.
I got them cleaned and tested before I installed them. The spray pattern was awful and the injectors were not flow matched within 2% error like they promise. I seriously replaced them with a top feed setup a month after I had them installed!
37 minutes ago, ADM33T said:
It's def a mixed bag of responses of using re-manufactured side feeds that's for sure.
Its quite simple really - if they are in good cond they work. New tech ones work better. PM Scotty and see if he can supply new ones for your sidefeed rail.
http://scottyscustoms.com.au/
Don't do it.. you'll hate yourself.
Nismo 740s or straight to top feeds. You can fit top feeds under the stock plenum without any issues if you're using 1/2 height injectors.
http://www.trak-life.com/diy-converting-top-feed-injectors-r33-gts-t-skyline-rb25det/
10 hours ago, ADM33T said:
Thanks Dose, I've read a few of your reviews and feedback regarding them.
Il ponder a little more and go from there.
More funds in the short term, less funds in the long term, & less hating of yourself
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
