R34 GT Indicator not Cancelling
Hey All,
 I just took the steering wheel off my r34 to make it straight. (It was about 3 degrees to the left) and when i went for a drive to make sure it was working correctly. I noticed the indicators have stopped cancelling automatically.
There are 3 little 'pins' around the metal column. these appear to be moving with the wheel as it turns.
I Cant see what else would be causing this. Has anyone had this issue?
https://www.sau.com.au/forums/topic/466753-r34-gt-indicator-not-cancelling/
  • 3 weeks later...
Hey mate,
Not sure if you fixed the issue by now. Its to do with your clock spring/cam position. You must of rotated it while the wheel was off which rotated the cam/clock spring, placing the notch that dis-engages the indicator in the wrong position. Hence why your indicators are stuffed up.
I did the same thing on my evo, i simply removed the clock spring and rotated the cam back into the correct position then carefully placed the clock spring along with the steering wheel back without rotating the cam.
See my horribly drawn diagram below: It takes a bit of effort to decipher, but thats basically what cuts out the indicator. Let me know if you need more clarification
Simply put, the cam rotates along with the steering wheel which presses the indicator notch which releases the spring and cuts out the indicator. All you need to do is put it back into its position.
  • 8 years later...
Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues.
I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
Edited by silviaz
15 minutes ago, GTSBoy said:
For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
No clips on this one like the other connector. Only that red tab that I can push slightly up.
  • 3 weeks later...
I finally figured this out. That green part, can actually be pushed out. Mine was on the wrong angle because I messed around with it. So what needs to be done is the clockspring to be removed (the loom can't be removed so you need to pull the cable towards you to remove it off the shaft then let it rest on something so it's not dangling)
Then you just make sure that the 3 green dots form a triangle and that the 3 holes on the steering wheel inserts into the 3 holes on the green part (you need to push out the green part to do this otherwise you'll keep having the issue with the indicators not cancelling)
  • Like 1
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
