Hi all,
Made some major changes to the car so the following parts are up for sale:
R34 GTt APEXi power FC with commander and boost controller- $700
PFC with hand controller, boost control kit harness, 3 bar pressure sensor and solenoid, great plug and play ecu and boost controller without having to cut and shut stock wiring, good condition had no issues, just selling since I decided to give e85 flex tune a go this time hence I'll need something different.
Hicas lock bar- $80
Comes with almost new tie rods, only used for less than 10000km, tightens the rear of the car and keep the back end planted. suits r33 and r34
Hardrace adjustable caster rod- $150
Adjustable caster rods, rubber version with the rubber replaced by Superpro urethane bushes, keeping it legal whilst getting a sharper steering
 suits r33 and r34 and maybe r32
Split dump- $50
Short split dump hks style to suit all rb20 and rb25 cars, heat wrapped, pulled 270rwkw with it on highflow turbo
Braided turbo lines (brand new)-$60
Mamba Braided water line x1 and braided oil line x1 to suit rb20 and rb25 standard turbo. Oil line suits standard ball bearing turbo, makes turbo installation and upgrades a walk in the park
Located in Sydney, Chatswood. PM if interested, happy to post at buyers expense.
Photos to come soon
https://www.sau.com.au/forums/topic/466810-lots-of-parts/
Got brand new Blitz SBC spec S for sale - $350
Brand new still in box, only opened up to take photo
It is the latest model and it is much easier to tune than previous SBCs
Was going to put it on my car but decided to just use the used AVCR I have pulled out of my old car anyway. So here's your opportunity to grab a bargain!
Located in Sydney will post at buyers expenseef89186aeeba921e6f1c9b903a231230.jpg1fe17051130895fd194ea950994dd848.jpgc3dc73bbf51cb7aef6e0d8ceb7f9c692.jpg2b5f28e86746e4ccecd434b9886f0350.jpgef10ebc4b72d393e2e161e1dbc07a6ff.jpg
https://www.sau.com.au/forums/topic/466810-lots-of-parts/#findComment-7777659
Price drop, SAU Special!
R34 GTt APEXi power FC with commander and boost controller- $650
Hicas lock bar- $70
Hardrace adjustable caster rod- $120
Split dump- $40
Braided turbo lines (brand new)-$40
https://www.sau.com.au/forums/topic/466810-lots-of-parts/#findComment-7777827
Also got a set of bronze/ gold buddyclub P1 racing 2 wheels for sale- $650
Size: 19x8.5 +38 offset and 19x9.5 +45 offset
Comes with 235 wide tyres on the 8.5 inch wide wheels and 265 wide tyres on the 9.5 inch wide wheels. All tyres have approx 60-70% thread.
The front wheels will not clear gtst and gtt 4 pot calipers due to spoke design, may just clear if you grind the Nissan logo away from the caliper, but since it's advertised on SAU, I will throw in a set of high quality GKtech hubcentric spacers, 15mm billet aluminum with high tensile extended studs and wheel nuts to suit.
Should fit the non turbo r34 with ease however.
Aluminum hub rings also included as part of SAU special.
They'll fit R34 and R33 non GTR cars without guard work, it was fine on my car lowered by 30mm.
Selling because I need to clear up some space in my garage, plus needed funding to finish off work on my car.
https://www.sau.com.au/forums/topic/466810-lots-of-parts/#findComment-7778281
Still for sale:
Hicas lock bar- $70
Split dump pipe- $40
Surely there are some skylines out there still with leaky caster rod bushes and HICAS still attached. Good opportunity to upgrade the handling of your car without paying a premium!
The lock bar also comes with new tie rods and dust boot so you won't have to worry about getting new tie rods when you upgrade!
https://www.sau.com.au/forums/topic/466810-lots-of-parts/#findComment-7778430
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
