My pride and joy r33 w/ rb26
Thought it was a good time to start abit of a build thread, have had my skyline for just over three years now and have went from a standard low mount setup to twin high mounts and now a single twin high mount setup.
engine
RB26 r32 engine rebuit with crank extension
new n1 oil and water pump
6boost manifold
garret 35r turbo
splitfires coilpacks
custom oil catch can
eplaced radiator hoses
Aluminium radiator
front mount intercooler
Fuel
Turbosmart 1200 FPR
Id1000 injectors
twin Bosch 044
3L surge tank setup
race works billet fuel rail
Suspension
Tien coil overs
adjustable rear lower control arms
adjustable rear camber arms
adjustable castor arms
Exterior
slim line boot wing
roof wing
series two lip extension
ssr meshies
Just added a old photo from QR and a more relevant engine bay picture for now, still need to powder coat rocker covers and finish of catch can setup
  • Like 1
https://www.sau.com.au/forums/topic/466877-my-pride-and-joy-r33-w-rb26/
thanks!
the main aim for the build is reliable/ comfortable daily with enough power to hit the track a few times a year. Here's a couple of photos from rebuilding the omanifold area.
powdercoated! raceworks fuel rail, ID1000!
Older photo before covers where stripped and catch can setup was mounted!
  • Like 1
Got a spare hour to work on the catch can setup, managed to get the other hose sorted out.
Catch can setup done!
Twin bosch 044 should arrive sometime this week to go into my AI fuel setup and start fitting that put in the boot!
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
