Is PM35 suspension same as M35?
I've got a 2005 350RX and whilst it never handled like a go-kart, over the past year it's turned into a jelly boat - more body roll than the Michelin man and I'm getting wear on both shoulders of the rear tyres.
Was under it the other day to change belts and brake rotors and it looks like the chassis end bush on the ??compression rod?? is torn on both sides, and the sway bar mount bushes are a bit knackered. I'm thinking it's time to swap the old rubber bushes out for urethane ones, but a bit lost trying to find part numbers. Does anyone know if the suspension is the same as the RWD 2.5L's?
Are there aftermarket sway bars that would fit? I'm not really keen to lower since I regularly need the ground clearance getting in and out of a couple of driveways, but something needs to be done to reduce the body roll.
BTW, I'm in NZ, but assuming that even if stuff isn't available locally, I should be able to get most stuff shipped across the ditch if necessary - just gotta figure out what to get!
https://www.sau.com.au/forums/topic/466921-is-pm35-suspension-same-as-m35/
Also have a PM35.
Pretty sure the suspension is the same as the RWD 2.5Ls (which I think are fairly rare...)
Mine was a whale when it first came in, but have since added Nismo swaybars, OX rear brace, Daleo's front brace, and just done the bushes on lower control arms and sway bar mounts.
Handles very well now...  Was even chasing 2 WRXs around corners :D
Rear is the same - front is different on the NM35 (AWD) which the majority of 2.5L are in AUS & NZ.
Front suspension on the NM35 is shorter to accommodate the driveshaft's.
You should be able to source some good suspension from Japan via YAJ perhaps?
2 hours ago, yuma said:
Does any other Nissan suspension bits fit eg 350z?
Yes mate, as long as you're talking PM35 not PNM35; there are a lot of compatible components in the driveline.
8 minutes ago, nagasakihacky said:
I'm in Auckland, New Zealand, so postage might be the killer, but would still be interested as I looked into bars a while back and couldn't find anything locally. Didn't know there z33 bars fit though
I have sent stuff to NZ; I'm generally able to secure a significant discount, so that might offset postage.
Let me do some research this week.
  • Like 1
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
