absolutely, the block and cradle are a pair. Even when they come together from the the same engine they should still be measured and potentially machined to make sure the main bearing clearances are correct.
  • Like 1
https://www.sau.com.au/forums/topic/467094-rb30-girdle/#findComment-7780959
so what can i do ? i have a block but no cradle, does that mean my block is useless ? do i just need to find a cradle and get it machined to suit block ? can i buy a new cradle from spool and get that machined to suit ? im lost
https://www.sau.com.au/forums/topic/467094-rb30-girdle/#findComment-7781608
Would almost be easier to keep your eye out for another complete block.. There's quite a few on facebook sale pages at the moment.
https://www.sau.com.au/forums/topic/467094-rb30-girdle/#findComment-7781610
I know it's not great news, and no you are not lost, they are pretty much your choices.  I'd either buy a different block (probably cheapest option) or buy a new cradle if that's an option (I assume its aftermarket and a different style). If you choose the latter you need to get the block tunnel bored which I don't really like in these engines because it moves the crank relative to the oil pump
https://www.sau.com.au/forums/topic/467094-rb30-girdle/#findComment-7781979
12 hours ago, Scott Black said:
with that ill just need to tunnel bore it right ? my block is 87mm and already been machined and cleaned n decked, so im not looking to buy another block, most likey just buy that girdle and machine it to suit right ?
https://www.sau.com.au/forums/topic/467094-rb30-girdle/#findComment-7782314
I could be wrong but I'm pretty sure you need to buy the Spool girdle in conjunction with their main cap kit which is another $1600 or so.  I could be wrong but I'm pretty sure that's how it works.  You can get the mains on their own but not the girdle on it's own.
https://www.sau.com.au/forums/topic/467094-rb30-girdle/#findComment-7782322
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
