hi guys,
Im currently looking at a few possible turbo options for my car. Im aim for 450-500Hp at the engine with this turbo. Now i first was hoping to stay with an internal gated turbo to keep the engine looking at stock as possible, but after doing some research, it seems that a turbo which has external gate will hold boost better, and have lower spoolup times.
Now is this true. Im paranoid about being defected, so basically if i can have a internal wastegated turbo that will hold boost well, then id be happy to do that, but if my setup wont work efficiently with internal gate, i spose ill have to go ext.
Im looking at garrett turbos atm. Is it possible to somehow fit the stock heat shield over a new low mount turbo setup? Im sure i could modiy it somehow to make it look stock.
Thanks
Dean
  • Replies 112
The HKS low mount manifold going on mine has provisions for a heat shield. But saying that it still wont stop a nice police man for defecting you for that non std. gear knob. U know, the big safety issue it is :D
With mine....well if you are gunna get pulled over for a bs reason...go the whole hog.
But yes bigger turbos were meant for external wastegates....if you wanna do it properly go the external. Im not saying people dont have good results though from an internal wastegate. The new Ford xr6 is a GT35 internal gate i believe...ford must have some trust in them :)
Regency (Transport SA) has final say. Engineers reports, ADR tests anything means nothing to them here. If they are unhappy with it, it wont pass.
They even defect ADR approved steering wheels, Engineers certificates, and emission tests (which here in Adelaide cost 2k+)
And you cannot take them to court, because they are covered by the law itself...
that's a hard one, 500hp+low mount+ stock looking? i think maybe you should raise your middle finger to the law! a 500hp motor is easier with a big single on a high manifold, but the first option i can think of is the HKS 3037 with internal gate, which may be hard to find.
if you are going to change the manifold go external gate, if keeping std manifols go internal. My reason being that the external gate position on the std manifold as per may last setup is not the best and its not easy to set up right. But if you are chnaging the manifold go external and mount it low down below the turbo.
Grepin runs a 2835r i think and is making 280 or so and its internal gate, JMS have on on their site for 2500 is a t25 flange but can use adaper to make it fit, this would be ideal. You will make a easy 250rwkw and shoudl do 300 just with a internal gate turbo.
I got a GCG 450hp turbo and it makes around 265kw at wheels.. Not sure on Hp, I think its about 360 or so.. Looks standard but hauls arse over the standard turbo.. But then again its around 2k for the rebuild so you have to weigh up what you want the car to be for before selecting your turbo setup ect..
$2000 to rebuild ur stock turbo or $2400 for a nice new twin ball bearing garrett GT30.
I know what i would be buying and did buy.
If u r serious go external gate, you know you will get bored eventually and get one in the end :)
Guest Robo's
Sounds cheap being a $400 difference, but show us the real costs in the transplant!
robo youd have to beat my car in arolling run because you have 3rwkws more and 600rpm less lag! ive just had my stainless manifold fitted and will be getting the car tuned shortley will post my results. i doubt ill get much ove 225rwkws??? if i had my $2000 to spend again id go a gt30 everytime . yes more stuffing around to fit but you stand to gain more power in the long run.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
