1996 180sx Type-x
Hi,
As much as it pains me to do this, the time has come and i need to move on with this car.
I am putting my beloved 180sx up for sale.
1996 180sx Type-x, OEM white 115km
The car was sourced and imported myself from Japan after searching for around 6 months. The car was brought in 100% stock, no rust no accidents, non smoking one owner and with genuine 75km on the clock. I have all the japanese paperwork and books.
Currently the car has 115km and is still in amazing condition with a few simple modifications. Interior is in mint condition and exterior is still all original with a few blemishes expected of a car this age. I am the only Australian owner and the car is regularly maintained and not thrashed. The engine bay is standard and still running stock boost, intercooler and airbox.
Mods on the car are;
-Raybrig headlights
-5 stud conversion with s15 brakes
-Tein super drift coilovers
-Cusco front strut brace and cusco 3 point rear brace
-Yashio factory shift knob
-Tomei expreme dump
-HPI twin front pipe (extra ground clearance)
-Dmax 3inch cat back exhaust
-100 cell high flow metal cat
-Will come with stock wheels
Has current registration until August 2017, no rwc
$16500
Sorry no swaps!
Located S.E Vic
0432777767
  • Like 1
https://www.sau.com.au/forums/topic/467192-sold-1996-180sx-type-x/
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
