3D Printed R34 aftermarket Triple gauge brackets
Hey Guys, I'm selling R34 aftermarket gauge brackets, that can hold any 52-60mm gauges behind the factory location in an r34 GT-T for a stock look. All brackets are 3D printed and adjusted to fit the required gauge size. The required measurements are in the photo below.
The gauges in the photos are all 60mm which is the correct size for the R34 triple gauge pod. 52mm will still fit perfectly but the bezel will be visible. As different brands of gauges have different sized cases and bezels the bracket can be made to fit one brand per bracket.
Super easy installation, just take out the factory Nissan gauges, insert your aftermarket gauges into the bracket and then plug in the aftermarket sensors and wiring that came with your gauge, screw the bracket into the factory triple gauge pod and then place back into the dash.
All brackets are $105 including express next day postage. PM to order yours
Edited by d.matho
  • 8 years later...
Damn, as someone who just glued the damn things in (very slightly askew but better) I wish I saw this, or someone made this.
Would be worth linking this to Boosted International. They're always looking for product ideas and this is something they would likely make.
    • Bah! I can't see the point in custom number plates at all. I went to the rego office, fished through a box of "premium" plates (the ones that had the "not as tall" option for the front plate) and picked the one that had a 32 in it. That's the limit of the effort and cost I will put into number plates. The only plate that I'd consider paying for would be 2332, but that's not possible here because it already exists from probably 90 years ago, and it would cost a fortune to obtain it, if it were available.
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
