Enkei rpf1
Hiya
im about to buy some enkei rpf1'a for my r33 Gtr and was going to order them in 18x10.5 et 15, after reading a few threads on here it looks like you have to stretch a 265 tyre to stop any scrubbing without rolling the guards.
The other option I thought of was to get the 18x9.5 et 15 and maybe put 10mm spacers on. Has anyone got any pictures of this size fitted to a r33 Gtr to see what the arch gap is like?
Or can anyone shed some more light on fitment on the 10.5's
my car is on tein coilovers and isn't sat too low
Any help is really appreciated
cheers
danny
https://www.sau.com.au/forums/topic/467345-enkei-rpf1/
I rolled the guards on 4 cars myself, all you need is a heat gun, guard roller and lots of patience. Unless the guards were repainted poorly, it won't crack (including aluminium guards).
But, if you don't want to, just get the 9.5" wheels and 265 wide tyres (forget about spacers).
https://www.sau.com.au/forums/topic/467345-enkei-rpf1/#findComment-7785451
I put RPF1's in 10.5x18 +15 on my 33 and stuck with the 265 sections.  Some brands run a little narrower at the tread however the Bridgies and Yokies I've had on it don't seem to be stretched at all, I asked a few tyre places about this and they said it's perfectly fine on that rim.  The Semi's run even wider as a 265 so sit perfectly.  I have no issue at all with the 265 on the 10.5.
https://www.sau.com.au/forums/topic/467345-enkei-rpf1/#findComment-7787502
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
