drag rear set ups
Hey all
Im looking at changing the rear end of my r33 gtst. runs about 400kws at the wheels. im struggling to get any traction even on a well prepped strip and slicks.
Below is a video, if you turn the sound up you can hear im on and off throttle the whole time and spinning/loosing traction the whole time.
At the moment it just has a welded diff and lower springs with soft shocks,
Starts i bog down then i struggle for traction when im up and running
What can i do to sort this??
video-1477097823.mp4
https://www.sau.com.au/forums/topic/467413-drag-rear-set-ups/
wallah
you need:
  • traction rods, extend them about 10mm - this will reduce the toe out ramp and camber ramp
  • camber rods, run about -0.5 degree or even 0 - because drag car
  • delete the entire HICAS rubbish, i.e. get a proper HICAS eliminator that deletes the ball joints for the hicas system
  • get a proper mechanical diff, the VLSD is aids no matter how much is "locks" it's all smoke and mirrors
  • subframe lock collars
  • diff bushes
Then alignment:
  • Toe in about 2mm each side, Nissans naturally toe out on squat
  • not too much camber
  • don't lower the car too much you don't want the control arms pointing upwards
I have about 370kW+ at the rears and I barely light up 2nd once the tyres are warm... albeit these are NT01, with the NT05 2nd gets a little silly.
  • Like 1
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
