High boost (~28psi) with -5s/2530s. what actuator needed for stable boost?
Hi Guys,
Got a question for those of you that have pushed big boost through low mounts (-5s/2530s etc)
I was using some dual port actuators from turbonetics with a 4 port solenoid in the hope they would provide a large control range for boost control, but they leak on the underside of the diaphram through the shaft hole so cannot hold the wastegate closed at significant boost and they also have a weak spring so are not suitable to just use as a single port. on closer inspection they're not going to work so I'm ditching them for some normal single port actuator cans.
the question is, what spring pressure will I need to use to hold 28psi on E85? is the 15.6psi spring of the garrett -5 actuators enough to not have them blow open at high exhaust manifold pressures or do I need to go to a garrett 19psi spring actuator to hold them?
it is a flex fuel car so on 98 I would like to be running around 20-22psi and up to 28-ish psi on E85 if possible.
the other option would be going to dual port turbosmart IWG-75s but they're quite a bit more expensive so would rather not and I'm not sure if they'll fit as they're pretty big.
thanks!
How big is the engine/how well does the whole system breathe? How much power are you making?
I had my -5's modified to increase leverage on the arm using the garrett stock item. I had them cracking at 24 psi but then brought it back to 19-20 psi. Managed to get it to hit 30 psi through the middle but tapering down to 26ish psi by 8000 rpm. That was making 472 rwkw on Unigroups dyno. (2.8, heavily modified head, big lift cams)
At some point, those little compressors are going to run out of puff/flow. if they cant supply anymore air then naturally the pressure is going to taper off.
4E81DE07-AB38-405E-922F-EF4AB4F5874B_zps
Appreciate your input guys.
Used to run the hks actuators but one was leaking so went the turbonetics dual ports.. but unfortunately the actuators shaft seal is a token effort and the spring pressure is around the 7psi mark so they're just not up to it and blow open dropping to 0.9 bar at redline. The turbo smart dual port IWG-75 units would be much better suited and I may investigate making them fit as I'm in for 130 bucks for a garret actuator or 200 for the turbo smart dual port with the option of adding more springs down the track.
Engine is a JHH built 2.6 with headwork, hks2530s proper 3 inch dumps, equal length front pipe and 85mm exhaust, 260 x 10mm cams and PAC beehive springs. Has made 550whp at 23psi in the past. Full boost about 4600rpm.
Want to see how far these hks snails will go for fun really.
A big Efr is a few years down the road if I still have the car
Edited by burn4005
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
