R33 21u stock turbo for sale, had approx 150,000km before taking out, run on 10psi max.
Has a slight amount of front to back shaft play but rotates smoothly and the blades are undamaged. Was working perfectly when it was fitted 3 months ago.
$200 negotiable
R34 turbo neo bottom end for sale.
This was bought off another forum member and i was going to use it in a rebuild because a tuner diagnosed my motor current motor as stuffed.
Didnt end up using it because:
1. My motor was fine. Tuner said no comp however i tested comp myself multiple times after that and it was ok.
2. Tuner told me to buy r34 block to rebuild r33 motor. I bought the block not knowing 33 head wouldnt be compatible with the neo block. I assumed since he specialises in jap cars and skylines he would have known this. Obviously i should have done my homework to check this instead of just assuming he knew what he was talking about
It is off an auto r34 turbo sedan that was completely stock. Looks to be in great condition. Unsure of the exact number of km to be honest but i was told it was under 100,000 and judging by the pistons and bores i would say its likely.
Have paperwork with the bottom end.
$550 negotiable
20161018_161742.thumb.jpeg.50375e6320e8120161018_161837.thumb.jpeg.84d574594715c20161018_161735.thumb.jpeg.1897fef5adaa020161018_161723.thumb.jpeg.49dfd88d17ee420161018_161713.thumb.jpeg.8c64c9c5daa9f20161018_161657.thumb.jpeg.ad7b6d92a90d1
  • 5 weeks later...
Sounds like your tuner isn't too clued up!!!
Tell me about it.[emoji58]
It just shows you should ALWAYS do your homework when buying parts.
Even when the person telling you to buy works on and tunes skylines for a living.
  • 3 weeks later...
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
