Here's my situation.
I had to put a new clutch in my 33 gtst.
I have the front of the car on stands and the back on the ground. New clutch is in and alligned with tool supplied. I have a trolley jack at the front of the box and rear of the box.
As I'm trying to get the input shaft inside the clutch I'm just missing out (half of the input shaft). I can't go up with the box anymore cause it's hitting the tunnel (if I went up the input shaft would be in). I have rotated the box up so the stater part is towards the bonnet.
Anyone have any tricks of the trade or done this before to give some ideas?
Thanks
https://www.sau.com.au/forums/topic/468312-refit-gearbox-help/
Do you have the front of the engine jacked up so the back is lowered? This helps with angle. Should allow you the room you need to get it in. If I'm having troubles I get someone to get inside the car and throw a rope or tie down around the back of the box and then remove the jack from the back of the box and get the person with the rope to adjust the angle as needed while you manhandle the box from below. It should go in the right side up. Good luck.
Don't forget to disconnect the exhaust or it will be trying to hold the engine straight. And drop the front subframe bolts down so the engine can tip back further. The input shaft can only ever go in when it is straight to the crank
Pig of a job with one person on the ground....going to need lots of patience
I havnt tried Adam. I plan to give it another crack tomorrow.
Cool, as stated above, patience is required. Everything has to be 100% lined up for it to go in and then it will pretty much just fall into place. If it won't go, step away for a while, clear your head and try again later.
Where did you jack the motor up from exactly?
I put a block of wood under the front lip of the sump and jacked it from there.
I jacked the front of the motor up, input shaft went straight in!!!! (f**k yeah)
Then i was having trouble getting the splines to line up so I took the jack out of the motor and she went straight in!!
Thanks for your help!!!!!! (I'm so relieved)
  • Like 2
No probs mate, it's a great feeling when it finally goes in. Congrats on completing one of the worse diy jobs on your car. Enjoy the new clutch[emoji106]
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
