C34 wesh plug mod
Hi all. I know it might have been covered before i just don't have the time to look on all the pages.
I have a s1 c34 and am looking to do the wesh plug mod. The shop i am going to has done s2 but is unsure if s1 is the same.
I can't be with out a car if its different to do.
So question is are they the same part and way to modd as s2?
https://www.sau.com.au/forums/topic/468332-c34-wesh-plug-mod/
As far as i am aware through extensive research, no one has done this to their s1. I contacted the two who have done the plug mod on their s2, one originally from aus, the other from the uk, and both boxes were still going strong.
Now.. I spoke to a local trans specialist who used to do work on the re4 and then grew his business and now works on amgs bmws porches etc . He was against doing these 'mods' like shift kits, plugs, these days as it puts too much strain on other components. Once you have fixed one problem, another will arise as it is now the weakest link. He went on to say that once it starts slipping with more power just buy new shift solenoids. From there you are better off buying a stronger transmission.
I had my car tuned around a year and a half ago, I'm not using the retard function on gear changes and the box has never slipped once from doing this. Box feels extremely tight and shifts a lot faster than standard. I wouldn't be surprised if it could handle 50+ more kw with no problems as a street car.
On std tune In 30 deg weather on throttle for about 30mins would cause the box to slip. I haven't been able to make my box slip since it's been tuned.
I posted all the information and lingo used in our conversation roughly a year ago along with his workshop number as he had great prices on the solenoids. I can't find it, but maybe with some clever searching you can :)
I am far from a trans specialist, but i took his word for it as he has seen it all.
  • Like 1
Its not too expensive to do the whole shift kit from MV (or equivalent) while you're at it. You have to remove the valve body anyways to put the welsh plugs in the accumulators.
1st to 2nd may be a little abrupt most of the time, but once you're on the move the downshifts are so much more satisfying. Easily beats many modern vehicles.
Id echo what Tom says, the gearbox in standard form can slip due to heat and even between different fluids. The valve body mods eliminate all those issues, assuming the material on the clutches are still in good condition
    • Unless you're fortunate enough to buy a newer car, getting an older style plate to match your name/car is difficult because they've already been purchased.  Unlike other countries, personalised plates are locked to the country and not region, so there can't be multiple versions of the same plate but with a different area code.  Hope that helps
    • People use the numbers to make it look like letters to spell words/names, which is where the illegal spacing comes in. For example this GR Yaris
    • Today's rock removal from my stock pile out the back into a 4m³ skip bin, I still have a bit to go, hopefully there's enough room in the skip bin, it will be close My daughter and her boy was coming on Sunday to help, but, I got possessed by demons and started work as soon as the bin arrived at 1230 today Lots and lots of barrow loads were achieved  Currently I'm sitting on the lounge drinking beer thinking of how I should have waited till Sunday for some help, tomorrow will be a day off, in saying this, my day off will involve prep and paint of my alloy coolant and PS tanks with wrinkle paint (Jackie is in Sydney till Sunday so the home oven will get a run curing the paint....LOL)
    • That's why I said it is a meaningless term. Because there is more than one meaning that people can apply to it. When we said "highflow", that is exactly what we mean, and exactly what is done. In a highflow, they take your housing and machine them out to take bigger wheels, have a better internal profile, etc etc, and fit a new core with the different/better/bigger wheels.
    • Oh sry i do not know if i used the term right. What i meant is upgrade the internals and keep the housing. That is not "hybrid"?
