Full set R35 GTR Brakes
Hey all,
Complete set of front and rear Brembo Brake Kit off the R35 GT-R. This setup comes with:-
1) Front Brembo 6 pot calipers
2) Front 390mm rotors with centre hats
3) Front brake pads
4) Rear Brembo 4 pot calipers
5) Rear 380mm rotors with centre hats
6) Rear brake pads
Price: $6,700 Neg
Contact via PM
Need money for other parts!!
Picture for reference.. Will post actual pictures tonight.
  • Like 1
https://www.sau.com.au/forums/topic/468479-full-set-r35-gtr-brakes/
Bump..
If you don't have the money, then don't bother sending me low ball offers because you're a dreamer.. They are (from what I can see) the only set for sale in the country.. Not in a rush to sell
23 minutes ago, stag98 said:
Probably not interested and that's fine, but open to a swap? Front & rear set of AP Racing 6/4 pot calipers and discs?
Sorry Steve, Just after the money.
  • Like 1
potentially dumb question that may be of relevance to others....
I presume you were planning on using these on an earlier model 'R?
Is it possible to (for example) put these on a '32, and what is involved? What would end up being the minimum wheel diameter?
Hey,
It's possible to put these on any 'R.. You just need the adapters, a few companies sell them and depending on who you choose, determines the price you pay.
Also a small modification to the backing plate (Needs to have the lip cut off) behind the rotors and that's pretty much it.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
