Rb25det Neo vs Rb25det
Hey guys, new to this page, currently building a motor. I have a reb25det neo block, got some forged pistons that are rb25neo pistons, are neo pistons only compatible with a neo head or could I use a standard head with it? Cheers
https://www.sau.com.au/forums/topic/468527-rb25det-neo-vs-rb25det/
Hey Bailey
Im guessing your new to forums. Mate before you get smashed can I give you some advice?
It is etiquette to do some searching before you post up a question, use google to search this forum as it works better ?
Of course if you cant find what you need, post up. But Jesus and his deciples were toying with RB's long before you and I started playing with them so 9 times out of 10 it will have been covered 50 before.
hope I got in before the less subtle deciples just gave you both barrels
oh and you will find your answer ???
Edited by Watermouse
  • Like 1
10 minutes ago, Watermouse said:
Hey Bailey
Couldn't really find the answer I needed.
Hi mate, welcome to the site.. lots of good advice on here but lots of shit too.. if you look up most people have gone the total other way to you. People put the neo head on a non neo block for the vct and solid lifters ect ect.. so cant understand why your going opposite way? It does seem like it can be done BUT with alot of stuffing around and headaches as the tops of the pistons are different and stuff.. your best off getting the neo head to match as nissan put alot of work into the neo with the vct ect ect.. if you do end up needing a neo head please just pm me as im about to change mine over as ive just had 1 fully worked so i will have a spare soon and in perfect condition.. anyways i hope u can find what your looking for but i think most will tell you the same.. Cheers mate
I was just curious if there was a difference I to save myself $400 ahhaha
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
