Overactive Radiator Fan
cherring
 Share
My car is an R32 Gtst. Not too long ago the fan started to run non-stop and after doing some research on here I replaced the viscous clutch with this one, but the fan still runs a lot more than it should, my temperature gauge not getting up above 70C on days that are about 35C, I'm not sure my thermostat would even open at these temperatures. Because of this I also replaced the ECU Water temp sensor hoping that that would sort it out, but still, the fan is going too much. I am not sure what to check next. Multimeter to make sure the sensor is getting power? Should I get a consult cable and plug ECUtalk and see if there is an error code?
I am not sure what I should try. If I need to just take it to a mechanic I will, but am trying to save the expense if I can. Any guidance very welcome.
Thanks guys.
Those viscous hubs are mechanical and engage at a certain temperature detected by the brass coil you see on the front.
ECU controls none of this.
I had an issue once when I purchased a brand new hub. It took some time before it actually started functioning correctly.
I believe there's a run in procedure you need to follow when installing the new hub. Were instructions included with your new hub?
I called it quits and found myself a near new condition R34 GTT hub which also suits the R32 fan. Genuine item and at least 10 years newer.
No issues so far. I have 3 spare genuine hubs all in working condition. If you want to go that route let me know and I can send one your way.
Edited by jmknights93
For what its worth, I've had a Davies Craig fan hub, and it was the worst thing in the world. It may as well have been a solid fan hub, it NEVER went any speed besides flat out. The genuine fan hub on the car originally was by far the best. I have a Dayco fan hub now designed for an RB30 in an R31 Skyline. This is only because it doesnt have as long a shaft and I had some clearance issues with my new radiator and fan shroud. I would say it is just about on par with a genuine one. Probably due to it being for a different model, the temps its designed to work at might be a touch different, but for the most part it is perfectly fine.
FYI genuine ones are about $300-$400 usually
Mate had the same issue with his 33 when he had a Davies Craig clutch too. I swapped it with an old spare I had and never looked back.
They are really horrible.
The Dayco one I bought is way better
 Share
    • I have been looking at some setting on the alarms for the Q60 and what buttons do and so and also been looking for details on the alarm in my V37 which is a standard issue with the car. settings like window roll up and a few others seem to not work at all. i cant seem to find exact info on V37 alarms so Q60 is all i can really go off i have not tried 400Z alarm settings or info yet so that will be next. any one got like a sheet of info on the alarm system in the V37 as all my documents are in japanese but i thought the system would basically be like standard through similar models?
    • I had a fuel smell coming from the drivers rear and pulled the tank out to inspect where it was coming from, turns out the breather hose from the tank to the filler neck was perished. I’m going to Japan next week and I’ll grab it while I’m there  pulled the oil tank apart and started cleaning this crap out of it, some brake cleaner and rags got it looking new again
    • Hmm. Was quite a few years ago now. I think I bought from a crowd in the US called CDT Audio. The speaker is the HD-6. The HD-6CF would have been the better option (based on T-S parameters), but they were discontinued in 4 ohm at that point in time. The HD-6 is a better driver in almost every other way (than the CF) - just not as good in IB. They still do the HD-6. They might even have a more suitable (for IB) option here.https://www.cdtaudio.com/cdtnew22/products/components/woofers/midwoofers/midwoofers.htm But, here's the rub. I was working in the US a lot back then, so I got them delivered to my US office and then just brought them back to OZ myself. I don't know if they will ship to OZ, and it probably wouldn't be great cost-wise anyway. As to results. They're driven direct off the rear channels of my headunit, because the headunit can be setup to run the rears as subs. So, not a lot of power being fed there. Nevertheless, there's no shortage of volume - the sub levels don't need or want to be boosted at all. The bass is definitely not what you would call "tight". It is definitely a bit delayed compared to a proper sub. But, with the great front soundstage and really good 6.5" woofers in the front doors, I'm getting most of the bass detail from the front and the rear is really only to extend the bottom end a bit. Works for what I'm doing. I mean - until recently you couldn't really hold a conversation in my car due to the fuel pump, and for many years I had tyres so noisy (Kumho KU36 at <50 tread depth) that I had to drive with earplugs anyway!
    • curious to know what drivers you chose and the results? quik mafs, says two 6.5s should roughly equate somewhere between a single 8" or 10" driver. i agree that IB is definitely the way to go in most cars imo.
    • S13 and R32 rear suspension geometry is horrible once you lower it (which everyone does). The camber & toe out ramp is very aggressive, hence it's common for the S13 boys/girls to use a S14 or S15 subframe as the geometry is light years ahead. I'm sure the same can be done on R32s, but I don't know anyone that has done that.
