Depends what you asked for
http://www.kudosmotorsports.com/catalog/water-pass-heater-hose-piece-nissan-skyline-p-1653.html
From the Kudos website for the R32 GTR. $312 for the genuine Nissan 10 hose kit
But if your OCD like me - there is also air hoses (2 or 3) and the radiator hoses upper and lower ($150). and for good measure at a great price is the metal water tube (under plenum) for $40 and water tube on the upper timing case.
I reckon it would be worth changing all of my hoses as the car has been sitting in the weather non running for 10 years, I will show you what kudos quoted me
2380_2017-03-27.pdf
That's good, a good price. Probably remove the SAMCO upper and lower radiator hose set for $128 as your quote already has the OEM set in it.
Grab the metal under plenum tube for $38 and water tube on the upper timing case. Tendency also to either rust or leak.
You have all the blow bye hoses included too.
So yeah, a very good price. :thumbsup:
Edited by Sinista32
You have all the blow bye hoses included too. So yeah, a very good price.
Cheers buddy, appreciate it
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
