Hi all can anyone with experience tell me if 18x10 +30 te37sl will fit straight on to 95' series 1 33gtr vspec. I know I will have to roll rear guards as fronts already done factory I assume, but nothing else major needed to just fit and drive away. Brakes are factory brembo still.
TIA
https://www.sau.com.au/forums/topic/469773-te37-fitment/
  • 1 month later...
Thanks for replies! So got the rims, black te37sl 18x9.5 +30 they are....stoked!! Still need a spacer for strut clearance ? And if so looking at the eBay alloy aluminium 10mm universal for all 4 or just for rear? Are they ok quality wise ?
https://www.sau.com.au/forums/topic/469773-te37-fitment/#findComment-7827120
Can I ask why u bought +30 offsets and then still plan to put spacers on?
If you bought the correct offset then you would have no need for spacers.
With a 10mm spacer you are going to need to get longer bolts
https://www.sau.com.au/forums/topic/469773-te37-fitment/#findComment-7827178
The rims are second hand and that's the offset they are, didn't think it would be too much of a drama. So buying spacers with the holes to fit over studs then the additional bolts attached to spacer would be the better option?
https://www.sau.com.au/forums/topic/469773-te37-fitment/#findComment-7827183
So after speaking to a knowledged skyline owner himself he said go 25mm spacer minimum if you want to fill the guards out nicely and should have no troubles with rim or tyre rubbing on strut on inside or tyres rubbing on guard. Sounds like the go, opinions? As I particularly wanted these rims and they came at a very reasonable price I just have to live with the spacer idea.
https://www.sau.com.au/forums/topic/469773-te37-fitment/#findComment-7827204
Its pretty easy to remove the old studs yourself but the rears are a bit annoying, you have to take apart the handbrake drum assembly to have room to remove the studs.
If your going to run 10mm spacers id say get the GKtech extended studs and 10mm hubcentric slip on spacers.
If your going to run bolt on spacers you wont need extended studs.
If i were you i would sell the wheels and just get proper fitting ones, they will look more aggressive, have better grip and are safer. Bolt on spacers are dodgy as imo, i wouldn't trust them. Hubcentric slip on is better but no spacers are preferable.
https://www.sau.com.au/forums/topic/469773-te37-fitment/#findComment-7827234
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
