R33 GTST wont start with Haltech ECU
Hey there,
So i'm new to this forum and i did some looking around to see if i could find anything similar to my problem and there were a couple but not 100%.
Anyways the problem i'm having is i bought a haltech platinum sport 2000 (the plug n play) and i installed it simple enough.
While i was doing this i also installed some nismo 555cc injectors. The base map that comes with the ecu is set for the stock injectors.
now after adjusting the fuel map the car wont start i tried messing around with some of the other setting to see if I could find anything wrong but to no solution it will crank but its only cranking around 150-200 rpm.
I'm getting fuel i even tried using some starter fluid to see if that was my issue but nothing . i'm pretty sure that my timing is off but i'm not certain if anyone would be kind enough to supply me with a map for the injectors i have or if anyone wouldn't mind looking at my map to see if they can find something wrong with it i would eternally grateful.
Edited by Johnsontke
updated info
Ya i loaded a base map and changed the injector size i also looked around and people were saying to do some math like stock injectors divided by new size and reduce the fuel table by the difference. which map sensor would be the correct one?
Ok sorry for responding so late i just checked it and its dropping to around 8v then itll jump up to 10v and it actually revs a good amount it sounded like it wanted to start but it wouldnt and then i got the smell of gas pretty hard. So i checked the cylinders but they arent flooded so im gonna stick the battery on a charger tonight and try again tomorrow any other suggestions?
PM me your exact mods, and what is connected to what input and how everything is wired up e.g. AN1 goes to IAT, etc.
I'll send you a tune file tonight when I'm at home on my tuning laptop.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
