R32gtst
So I've decided to buy a r32! I'm pre approved for a loan but only have 2 weeks to use it. I have the option of about 3 cars. 2 of them have rb25det but run RB20 transmissions. And 1 has the standard rb20
The 2 rb25det are around the $10-12k and the other is $6k
I have a budget of around $15k
Question is am I better of buying the 25 swapped ones and spending a few thousand on mods. Trying to reach the 250kw -280kw with a budget of around $5k
Or buying the rb20det one and having around $9k to spend and doing a 25/26swap ?
The car will be only used as a weekender and maybe a track day once a year.
And whatever one I get will be upgraded over the next few years.
https://www.sau.com.au/forums/topic/470149-r32gtst/
$5K will not bring a stock RB25DET up to 250KW and upgrade to a big box transmission. Do not have your choices dictated to by financiers. If you are good for a loan take your time finding the right car and use another lender if necessary.
https://www.sau.com.au/forums/topic/470149-r32gtst/#findComment-7825361
3-5k to bring a stock RB25 to 250-280kw is a joke right? Injectors, turbo, ecu, RB25 gearbox, clutch, tail shaft, tune plus all the other small things your looking at $10k minimum. If you want to be able to make stop, turn and go you are going to need a 1.5 way LSD, decent pads and rotors, briaded brake lines, tyres, new suspension and new bushes, that's another $10k there.
My personal opinion is don't get a bank loan for your toys, if you can't pay for them straight up wait until you can.
https://www.sau.com.au/forums/topic/470149-r32gtst/#findComment-7825407
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
