RB25 + R34 Garage Clean-out
Garage Clean-out:
Everything has been pulled from various working setups. Open to offers, prices copied from previous posts, welcome to inspect/test.
$300 - Blitz R34 RB25det Return Flow Intercooler
$850 - HKS GT-RS Turbo
$600 - Kinugawa TD-06 20G Turbo + Highmount Manifold (RB25) + TiAL Sport Gate + Custom Dump Pipe
$800 - Apexi Power-FC ECU with Hand Controller R34 RB25det
$250 - Impul R34 RB25det ECU
$200 - Custom Plenum Creations RB25 Forward Facing Plenum
$400 - Exedy HD Organic (NSK-7172SO) Good Condition
$50 - Stock GTR Fuel Rail and Injectors
$20 - Stock R34 RB25det SM Intercooler
$50 - Stock R34 RB25det Throttle Body
$50 - Stock R34 RB25det Pink Label AFM
$100 - Stock R34 RB25det Cams
$100 - Stock R34 RB25det Turbo - Suits Rebuild
$100 - Stock R34 RB25det Coil Packs
  • The Kinugawa TD-06 20G was part of an engine package I purchased. It apparently made ~300kw on an RB25, I have not used myself.
  • The GT-RS made a reliable and responsive 260kw on my R34.
  • Sold as is where is - Located Morningside, Brisbane.
  • Happy to provide further photos/info if required
  • Selling due to upgrades
I also have a Stock RB25 Engine available, currently stripped.
Cheers,
https://www.sau.com.au/forums/topic/470358-rb25-r34-garage-clean-out/
Motor is currently sitting at a workshop in Slack Creek - Brisbane Area. I'm going to have a chat to the builders to get a report on the condition. It apparently has forged internal goodies. Leave this one with me for today.
  • Like 1
Interested in motor. Please update when you can.
Ok awesome mate thanks for your reply... Also, Pmed you
5 minutes ago, gold-3lt said:
Plenum 100% gone?
Hey mate, I have a guy coming to collect it tonight. If that falls through for any reason I'll let you know.
Spewing. Got the notification of the ad on my mobile then read it intending to msg you about plenum but forgot. Been chasing a neo cpc plenum for ages. Definately message if sale doesnt go through
Gents, the plenum is for a Non-Turbo Neo. Even though it shows a it mounted to a turbo engine that engine must have had a non turbo head... Only found out tonight thanks to LaurelPWR. It's still available. Cheers
  • Like 1
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
