R34 GTT Mid-High range power loss
Hey Guys,
I'm new to this whole Skyline thing. Just bought myself a R34 GTT about a week ago. Runs great.. Besides getting sub 250km a tank.. Yeah.. I also feel when it comes onto boost its fine but as soon as you go over 4500 rpm it starts to splutter a bit then comes back. While that's happening its blowing a crap load of black smoke out the back. I'm assuming it has something to do with 02 Sensor? I had a look through the receipts and I saw that it has Spitfire coil packs.. Not too sure what they are but they were $600.(I mean I know what coil packs are) Previous owner must of got a CEL because he got it diagnosed and it said bad 02 Sensor. Next question is how much and where is it located... If it's even got to do with the 02 sensor.. Im not sure.. If someone could help that would greatly be appreciated.
https://www.sau.com.au/forums/topic/470533-r34-gtt-mid-high-range-power-loss/
Hey mate.. Yeah well first problem.. The guy that owned it put 3 Defi gauges in. Decided to wire all them up to power.. That's it. So I actually have no boost gauge.. Would be good if I knew how to get one working haha.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
