Evo Brembo Brake Conversion
Hi, I was looking around at pricing and options for my r33 gts-t and the evo brake kit looked quite good.  Where is the best place to get the brackets from ?
I found this place cheaper http://madparts.net/version-2-evo-89-to-nissan-240sx-brembo-caliper-conversion-br289240.html
I know alot of ppl have used Alpha Omega for their brackets.  Im all for buying local but their prices are a bit high.  Website prices don't include GST or delivery
http://alphaomegaracing.com/c/63/R33.html
Calipers with gst and delivery will be $1450-1500. You don't have to look to hard to find these at around $1k
rotors $520+, can get for about $400
brackets are around $900 with gst and postage. I think for just a few brackets that is a bit steep, when the brackets themselves cost nearly the same amount as the actual evo calipers.
http://alphaomegaracing.com/i/9/Evo-Brembo-Brakes-On-A-Nissan-Adapter-Designs.html
Any other thoughts or ideas ?
Edited by R377
https://www.sau.com.au/forums/topic/470569-evo-brembo-brake-conversion/
4 hours ago, GeeDog said:
Probably is, but a cheaper option is this
If you were interested in the cheaper option, I know where there is a set for sale in SA....
thanks for the reply, could u plz pm the details
I found this a bit cheaper from HFM with rears aswell
https://www.hfm.parts/product-category/brakes/brake-kits/
5 hours ago, GTSBoy said:
Isn't this the answer to your question?
Ive googled quite a bit on here and you come up quite a bit in brake threads so u know your stuff.
Evo brakes around 1400-1500. The Attkd brakes are around 2200.  How much more better are the attkd brakes compared to the evo brembo's ?   Also for future parts like rotors and pads would the attkd be more expenisve with less options than the evo's ?
My thoughts are that once you get to the point of spending as much as you have to to put Evo brakes onto a car, that paying a little more for brand new equipment is probably worth serious consideration.
There are plenty of people on here who have these or related brakes on their cars and love them.  They use a common sized pad.  And when the rotors need replacing you will probably find there are options available. I haven't looked into that part of it because I'm not looking for more braking.
  • Like 1
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
