Fastest rb20det r32 UNOPENED MOTOR
I'm courious to find out what's the fastest 1/4 mile time time of a r32 chassis rb20det UPOPENED MOTOR. And what power figures people are making with them unopened
any info use have on times of people and power figures would be good
https://www.sau.com.au/forums/topic/470631-fastest-rb20det-r32-unopened-motor/
There is a dude on here from the US with an unopened RB20 in an FC RX7 who claims to have run a 10 second pass. I believe he posted more info in the drift and drag section. No idea about R32 RB20DET time slips.
