Skyline r33 fuel injectors guidance
Hi guys my car fuel consumption is so high it's doing 250 per tank 55 litres means 20 litres per 100 km . So had oil nd filters changed mechanic said spark plugs r ok .
so now I am thinking to replace its fuel injectors. Currently looking on eBay but confused which ones are good for me. 750 cc nd 550 cc company brand my4 . Also can someone tell me do I have to change other things to replace the injectors on my car . What's the factory injectors info like (what cc or brand ) etc . Can I use the same coil pack for new injectors as it's already on the car I mean factory coil pack or I have to change coil packs too according to new injectors? Thanks guys hope to get some good information cheers
https://www.sau.com.au/forums/topic/470864-skyline-r33-fuel-injectors-guidance/
There are a number of things I'd check before replacing injectors dude:
  • Oxygen Sensor
  • Intake/Filter - check for blockages
  • Temp Sensor
  • AFM - might need a clean
  • Thermostat
  • Vacuum leaks
All of these things are far cheaper and easier to address than injectors. Have you done the basics? Low tyre pressure combined with old/thick oil can actually affect fuel consumption pretty dramatically. Are you running good, 98RON fuel?
Maybe try a reputable fuel system/injector cleaner too.
  • Like 1
You can't really change the injectors with the stock ecu. You could get them cleaned and tested. Did the mechanic actually pull out a spark plug to have a look? By the time you have gone that far one would normally change the plugs anyway. If you look in the DIY section you will find a guide to changing the plugs. get new ones gapped down to 0.8mm. Give the coils a good clean and if you see any burn marks where they have been shorting you should ideally replace them with OEM or Splitfires (or at least spray or wrap them with insulating tape).
If you can go through the list in the previous post. Dirty air filter is a top suspect. There is a DIY somewhere on how to clean AFM. If you want to know how to do something Google the question first and you will usually find the answer. If you don't usually do your own work get a few tools and start now or your Skyline will keep you poor!!
  • Like 1
  • Oxygen Sensor
  • Temp Sensor
  • Thermostat
  • Vacuum leaks
This is a great list!
Before doing anything related to the injectors check all these things above first. Also put in new spark plugs, new fuel filter and new oil. After doing all the things listed above start writing a log and the come back with those results and we can help further. Have fun!
  • Like 1
Hi guys it's temp needle never goes up it always few minutes to come normal level so it's can't be temp sensor or thermostat. Um just gonna change its air pod which not much $$$$ and will clean AFM thanks. But whenever I start cold engine like next morning it's turn up but after couple of rounds it's goes off . But day time it's alright just 1 round nd runs smooth. Any idea why ?
There are two temperature sensors, one for the dashboard gauge and one for the computer to operate the fueling tables, so yes it still could be the cause of your issue.
O2 sensor
Computer Temp sensor
and bad/ stuck thermostat.
They are your most likely culprits.
O2 sensor
Thermostat is a likely culprit. I'd say change it either way.
This is incorrect, as missleman said there it 2 senders. If the sender for the ECU has died it will be reporting full cold temp and as such the ECU will compensate by adding lots of extra fuel as it thinks it is in very cold conditions. The temp sensors are on the inlet manifold near the top radiator hose. The dash one is the single pin and the ECU one is the two pin plug.
Thanks for your advice guys
I clean the AFM
had look on oxygen sensor it looks ok
spark plugs on the way to be replaced
had look on temp sensor not sure they working properly but looks ok too
but I can tell yah my car has bad starting in the morning. Daytime it's ok but morning time it takes 2 push or I have to accelerate to help engine turn up . I am really confused if it's temp problem then it shouldn't have starting problem. Looking to hear you again please
At this stage I would stay patient until your spark plugs arrive. Put them in and see if that fixes your issue, as it may well be them.
After that, I would start by replacing the O2 sensor, temp sensor (2 pin) and thermostat. Sensors can be got for around $40ea and the Thermostat around $50.
We've given you the advice mate, just have to follow it :1310_thumbsup_tone1:
  • Like 1
  • 1 month later...
Hi guys um back with same issue I have replaced spark plugs nd splitfire coil packs but car still sucking the fuel same way nd in the cold morning still has same bad starting engine just stall sometimes it seems like motor has breathing difficulties but not sure what it is any suggestions please. It's r33 by the way um posting pics very soon it's got front facing plenum, front mount inter cooler apart from that it's a stock car. Sucking fuel more than 20 litres per 100 km don't know why
    • You're not the first person that's said that about this car lol. A Touring wagon GT in Spark yellow mica would be the dog's danglies 😆 I will keep an eye out for a future purchase for sure. The seats are almost like the OEM Recaros... electric adjustment for fore/aft and tilt movements except reclining.
    • Yes!! I love these! It's a shame its not the wagon though!   Thank everything that's holy that it doesn't have the interior of the Aussie delivered ones. Those seats are so much nicer.
    • I'm both sorry and thankful that you do that.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
