fixing a buckled guard - worth it?
I had a minor accident a couple of months ago where someone reversed into my guard and buckled it and broke my headlight too. The guard got pushed in a bit (could tell because the line between the bonnet and the guard was much less than it was before). The repair guy told me he could fix the current guard but im having doubts. His gonna have to use bog on the guard obviously so im wondering if the paint finish would still come out 100% perfect as if he just painted steel, also how would it last the test of time? The mounts might be bent and all and im kinda worried that it wont come out 100% perfect. Could these buckled guards still be saved or am i best of just buying another perfect guard and making him paint that? Anyone have past experiences with fixing and painting a badly damaged guard? Its just that i plan on keeping my skyline for a long time and i want it to be perfect. Im mostly worried about how the paint finish will look now and over time and if he could pull the guard out from where the bolts are in the engine bay and line them up mint and and i want the mounts to line up 100% i.e i want it to be like a brand new guard. Is that possible for the smash repairer to do or should i just give him a new guard and get him to paint that? Thanks
Here is the picture of the guard in question :
https://www.sau.com.au/forums/topic/470919-fixing-a-buckled-guard-worth-it/
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
